For me 3.0.1 gives the following error, when i roll back the app to 3.0.0 the error goes away. Like @dand, I’m fairly certain 3.0.1 was causing 500 errors in my log too. After support pushed out patch 2.2.6.150 to fix the 500 error is when i saw this app was not a happy camper and rolled back to 3.0.0 to fix.
[error](http://xxx.xxx.xxx.xx/installedapp/configure/418)org.codehaus.groovy.runtime.InvokerInvocationException: groovy.lang.MissingMethodException: No signature of method: java.lang.String.call() is applicable for argument types: (java.lang.String, org.codehaus.groovy.runtime.GStringImpl) values: [debug, getEightSleepAccessToken: eightSleepAccessToken=3279164b92e2482795868039d3febc42-14f98cc15814187e6e45bf129b039a32] Possible solutions: wait(), any(), trim(), grep(), split(), next() (credentialsPage)
Thanks for calling that out. I also seem to have several throughout the day, so it seems like it's not just you. I don't remember seeing so many timeout errors before, so maybe something's changed or I haven't noticed it before. I'll play around with increasing the hubitat timeout setting and see if that helps.
Is anyone having a similar issue as mine where the "presence" state seems not to work? No matter if I am in the bed or off, the presence never changes and is always "present".
If I create a child presence for bed presence, that one seems to always be stuck in "not present".
So I have the parent device showing always present and the child presence always set as not present.
Waiting on my Eight to ship, but really curious on what automations you have running/written for yours.
Also, I know slightly off topic, but curious if anyone has input/experience on their shipping times. My order said it would ship between 1 to 3 days ago and it hasn't yet.
Thanks, i’m trying it right now. Been laying in the bed for about five minutes and so far nothing has changed. I take it that setting will toggle once it is detected that you are asleep? That might be a little slow for me. I was hoping to have it detect when I lay in bed so that you can turn off the lights. If it doesn’t toggle until I go to sleep, then I would have to sleep with the lights on at the beginning.
Eight Sleep introduced a new feature in the pod called Away mode. You can set yourself away and it will disable the sleep and wake timers. I don't know if this is controllable within their API's, but it would be amazing to have this feature within this app. If my controller goes into "Vacation" mode, then set the Eight Sleep Away mode to yes.
Maybe this is the incorrect way, but I know these few community members have experience coding and working with API's. Maybe @thebearmay or @snell would be interested in helping and taking over the driver/app?
Not much for the app side of things unfortunately. I actually HAVE an Eight Sleep pad (got a couple of them way back when I think Walmart had a mis-pricing, they were each like $20). Do not really use it too much though even in the winter. I started writing my own driver for it way back but got too side-tracked with my OTHER drivers at the time.
