[DEPRECATED] Echo Speaks
Hmm... I will add some more logging into that section before I release today.
The broadcast and announce test is not actually using the device handlers to send the commands which I need to make sure I didn't miss anything there.
I will let you know what I find
OK, happy to test for you when released, but don't want this to detract from your great work with this app! As an ex-developer myself, I know that these little things can take some finding!
This is one of my biggest flaws as a developer :frowning:
I'm always working on and optimizing stuff and working on new ideas that I likely got sidetracked and left something unhandled.
Just released :slight_smile:
Notice: The announcement test in the app needs more work. It's not setting the volume like I want before announcing.
In the most trivial of bugs...
volume::40,, speak::this is so silly,, wait::60, weather,, cannedtts_random::goodbye,, traffic,, amazonmusic::green day,, volume::30
If someone (me :blush:) copies the sample sequence phrase to test, the single comma after wait::60 causes the test to fail.
thanks for catching that
Great work with V2.4.0, it's solved my problems with the broadcast test and the announcement test.
Is this allowing custom text to speech ?
yes and much more
Thanks for adding Fabriq TTS! It works great.
I'm not sure if my next question is about Echo Speaks, or Rule Machine? I want to use the '%device%' variable in RM in a playTextandResume() custom command, but I'm not sure if that can be done? I have a RM that triggers on presence arriving/departing. I want the message to be '%device%' has left.' and %device% would be replaced with the device name that triggered the rule ... like 'Matthew has left.'
I created a RM Custom Command for PlayTextandResume('%device% has left',45) and it enunciates 'Percent device percent has left'. I could hard code a custom command for all five of our presence sensors, but hope to not have to do that. I also use a similar RM to says what windows are open, and we have a lot of windows so that would be a lot of rules to create if that are all hard coded.
Has anyone done this or have a suggestion I could try? Thanks.
I'm not sure how to answer that question.
but i do have a companion app in development that will allow for easy creation of performing these type of event based alerts
Just wanted to say thanks for this app. Got it installed very quickly and the first rule I made to test worked great.
I do have a question. I went in and renamed my fire cubes since I installed this. It updates in the app settings, but the names are not updated in rule machine. I have auto rename enabled. Is it just a waiting game or is something wrong?
I need to work on the rename under Hubitat. It works fine on the SmartThings side
For now should I just select the old name or do a reinstall of the app?
Just edit the names under the devices page
Will do. Thanks
Got it all set-up and working yesterday, but the Amazon cookie expired early this morning and I had to re-login to the Amazon service today, is this normal and how long should the cookie be expected to last?
I'm also seeing lots of debug message in the log, even though no speech is being used, this is a typical example period of 8 minutes....
dev:82019-01-28 06:22:51.317 pm debugAlexa Playlists Changed to [:]
dev:72019-01-28 06:22:28.369 pm debugAlexa Playlists Changed to [:]
dev:82019-01-28 06:21:51.350 pm debugAlexa Playlists Changed to [:]
dev:72019-01-28 06:21:28.401 pm debugAlexa Playlists Changed to [:]
dev:82019-01-28 06:20:51.345 pm debugAlexa Playlists Changed to [:]
dev:72019-01-28 06:20:28.348 pm debugAlexa Playlists Changed to [:]
dev:82019-01-28 06:19:51.384 pm debugAlexa Playlists Changed to [:]
dev:72019-01-28 06:19:28.329 pm debugAlexa Playlists Changed to [:]
dev:82019-01-28 06:18:51.377 pm debugAlexa Playlists Changed to [:]
dev:72019-01-28 06:18:28.422 pm debugAlexa Playlists Changed to [:]
dev:82019-01-28 06:17:51.349 pm debugAlexa Playlists Changed to [:]
dev:72019-01-28 06:17:28.338 pm debugAlexa Playlists Changed to [:]
dev:82019-01-28 06:16:51.346 pm debugAlexa Playlists Changed to [:]
dev:72019-01-28 06:16:28.483 pm debugAlexa Playlists Changed to [:]
dev:82019-01-28 06:15:52.050 pm debugAlexa Playlists Changed to [:]
dev:72019-01-28 06:15:28.326 pm debugAlexa Playlists Changed to [:]
dev:82019-01-28 06:14:51.456 pm debugAlexa Playlists Changed to [:]
Is this to be expected?
Thanks for reporting this. Your not the first users to say they are seeing this in the logs. (It's nothing to be concerned about)
You really shouldn't be seeing that log entry unless the new value is different than the current playlist.
I will investigate
OK, thanks. My other issue (sorry) is that I can't configure my Pushover device for the notifications, I can't get to see the list of devices to select my pushover device.
Yea that was another overlooked item. The pushover integration in this app uses my pushover manager app for a whole platform level support with no virtual devices. Support just needs to be added to the app.
When I get some time I will add support for the devices themselves.
