[RELEASE] Echo Speaks
#364
I just refreshed my cookie and it seemed to have worked fine. I also did a test to my bedroom echo and that worked as well:
UPDATE: My info may be off. I tried refreshing the cooking a couple of times and while the logs show current time, the app shows yesterday:
04%20PM
#365
Mine previously showed June 13. Now It shows nothing because I can't get it to refresh. The login page just keeps looping every time I enter my username and password.
#366
Yup same date for me
#367
Ditto
After logging the page states "Amazon Alexa Cookie Retired Successfully", but then comes back to the login page as if it was not logged in.
#368
Mine also.
#369
It finally broke this morning. When I went to the amazon login page, I needed to complete a two factor authentication (it sent a 6 digit number to my cell phone).
#370
Ever since I installed Echo Speaks about a month ago, it only works intermittently. At first it will successfully speak my message. After a few times, it will stop speaking. When I try it a day or two later, again the same pattern. It works at first, then stops working. I do not see any errors in the logs, but I do see a debug. I’m not sure if the display of debug in the log indicates a problem or not.
Echo Speaks is being called from within a rule, and the rule is executing perfectly except my message is not spoken after the first time, or after the first several times. Within the rule I have at least a 30 second delay between messages.
I’m on version 2.5 of Echo Speaks.
Any help would be appreciated
#371
I am still down and unable to login to Amazon and generate a new cookie. Anyone else have any success?
#372
Still down.
#373
I was wondering how long it would take Amazon to change something and break this.
Hopefully @tonesto7 can figure out the work around. There are also lots of communities that have used this method to integrate. I bet there are some smart people already poking at it.
#374
Not sure where you're all located but I'm in the UK and have not had any issues....yet! (kiss of death)
I've had occasional errors in the past and a device become unresponsive a couple of times, but all ok since 2.5
Possibly region specific?
#375
There are people on the SmartThings Community forums that are in the UK with issues.
#376
Ping @tonesto7
#377
I’m also UK and it’s down for me :disappointed_relieved:
#378
It is likely just a matter of a bit of time before everyone's cookies expire...
#379
I'm not sure why the cookies are now failing but if you're looking for a short term fix, you can manually enter the cookie and that seemed to fix it for me.
  • Open your echo speaks app
  • Click "Login Service Settings"
  • Click "Heroku App Settings"
  • In the Heroku pop-up, click "Open App" (at top)
  • In the new page that is opened, there should be a button to manually enter a cookie.
  • Follow steps here to get that info and enter it.
Mine seems to be working ok after that.
#380
wow... i try to take a couple days off work and relax with the family and shit hits the fan :crazy_face:
i need everyone to relax and let me try to catch up...
#381
i’m pretty sure this is related to the UK only for the moment. i’m in the US and token refresh is working for me.
I didn’t write the module used for the cookie collection and refresh. I have worked with Apollon77 on a couple issues in the past so we have a decent rapport...
the module used to handle the logon cookie process is GitHub - Apollon77/alexa-cookie: Library to generate a cookie including a csrf for alexa remote
I just modified to work with UI and run under heroku.
#382
Token refresh is not working for me and I use amazon.com
All I get is loop to get a new token using the Heroku login screen. Try a manual cookie doesn't work either.
#383
I’m in the US too and it failed for me.
