HA is slightly ahead of the game, since the new Echo Device integration is built directly into Home Assistant Core.
Last time I checked, you had to pay for Echo integration on HA, or jump through burning fiery hoops to set it up yourself.
I actually went the route of adding my devices to HA using the Alexa Media Player, and then wrote an app and drivers to send post commands to HA using the notify command in HA. There are two drivers, one for single devices and another to make groups of devices you pulled in from HA. It also requires a long lived access token created in HA, like the ones used for HADB.
I would share, but it was really my frankenstein invention to get around all the issues with Echo Speaks. Has been working well for a few days.
Supposedly, the fix for the built in Alexa Devices app is going live with HA Core 2026.11. That would allow you just to pull the devices in and use them with the speak command just like any other TTS device. The issue with the HA app (and likely Echo Speaks) is a redirect to a pop up authorization that Amazon just added. Full write up is here
Not any more.
That is the integration that is broken until Core 2026.11 is released. The only one working right now is Alexa Media Player.
Echo speaks is fixed above both the app and new docker container just fyi
It is currently working with Home Assistant Core 2026.11.0b4. Keep in mind that is a pre-release and may have bugs.
Are you experiencing issues with rate limiting with the Echo Device integration in Home Assistant?
Not sure exactly what you mean by rate limiting. The rate at which you can send announcements? Or the number of announcements per day or hour or something like that?
I've been away for two days but I hadn't noticed anything wrong before we left on Monday. Mostly I send announcements through my echos when one of my cameras picks up a person, or the doorbell camera detects a package, there's lightning in the immediate vicinity, and things like that. It's not talking to us all day long.
And I do have what you'd probably call rate limiting in my camera detection code. We have a 100+ ft driveway and I don't really want Alexa repeating over and over that someone is in the driveway every time an Amazon driver shows up and the camera fires off another detection.
Sorry. I should have been clearer. i am referring to rate limiting within/of the Echo Devices integration in Home Assistant. I started getting Amazon-side rate limiting, including HTTP 429 and too many requests errors shortly after adding the integration. It was taking my Echo devices offline in Home Assistant, and subsequently they'd stop working in Hubitat.
Where were you seeing those errors and how did you find out about it? Were they in the HA or HE logs?
I have Echo Speaks disabled in HE, but I was running that and HA's Alexa integration in parallel for several days and didn't notice anything unusual (except the duplicate announcements, which was expected).
HA logs.
Essentially the rate limiting disabled my Echo devices in HA.
I don't see anything in my HA logs, but I'll keep an eye on it.
You'd know right away if you're rate limited because the Echo device integration essentially gets disabled.
Hi, I'd like to ask if you can help me to identify the issue I'm facing when I initiate the Echo Speaks "Amazon Login Page" -> Go To Login Page -> enter my email address and following I got the below error. I'm using docker container version running on my Synology NAS. Today I got a message "EchoApp (v4.3.0.1) | Echo Speaks Authentication is no longer valid... Please login again and commands will be allowed again!!! | Method: (getEchoDevices)" so I was going to login to get working Echo Speaks again but I can't due to the below issue. Echo Speaks was working fine couple of years without any issues ![]()
read the above thread for patches for the docker container
Well, something happened overnight and now it's not working. Bunch of "Too Many Requests" errors and certificate verify failures. Great...
Thanks for the help, ES working fine now.
Funny thing is that mine seems to be stable now. Wondering if it was just a temporary Amazon thing. It's also making me wonder how well flushed out the native HA Echo Device integration really is. I know the login/authentication issue was just resolved with Core 2026.11.0. I've also read the the integration does in fact do rate limiting, but I am not what triggers it to cause the integration to essentially become disabled.
***EDIT - Now I wonder if the issue was due to the number of people installing and setting up the Echo Device integration when 2026.11.0 was released yesterday.
So what is the preferred method of deployment now? Seems like Heroku isn't working as I deployed a new app to it and when I try to login to amazon using the Echo Speaks app to authenticate, I get a no such app message. Redeployed many times and the same happens.
