Mine is showing over 50% of 82% total load.... no problems seen though..
82% - That's a hefty load....
I have 16 echos and over 200 zigbee and zwave devices.
That'll keep you busy, I'm at around 1/3 your numbers, mostly Z-Wave Plus (used a recent move to upgrade all of the old) with a few Zigbee.
So after the upgrade to 2.2.5.120 I get the following for all my Echo Speaks devices. I woudl delete them and recreate them but I when I click on the device I just get the error so I can't remove them:
# Error 404
### deviceId was not found. java.lang.NullPointerException: Cannot invoke method clone() on null object
### The Page requested could not be found
Interesting, mine are showing the same thing when trying to access from the devices tab, but seem to be working.
Yep, I can also send things to them that are already configured and they work. The device page just doesn't load.
I reverted to 2.2.5.119 and the device pages load just fine again.
If they're working I wouldn't worry too much at this point. I just checked the attributes and commands using a small app I have hanging around and everything is still there, so it's probably something small - guessing the DeviceID isn't formatted correctly for the page to display it.
Yep, same here on 2.2.5.220.
Can you let us know what is up in the new NP problem with 2.2.5.220?
Noted
You can add me to the list, can't open device page for echo devices
Do seem to be working, probably would not have noticed if I had not seen this thread and looked.
If I'm understanding the stat's correctly I believe the high percentages are just stating that of all device activity it's responsible for 26% of all activity. I don't believe it's using 26% usage at that moment.
I'm glad i had to go into the office today and haven't had a chance to update yet
Same 404 error for me post upgrade to 2.2.5.120
Yea, it looks like everyone is having this issue with the latest hub release (2.2.5.120).
Seems to be a page error not a device error. Support is looking into it though.
Hold off on downgrading... We are working on fixes right now.
There will be a maintenance release tonight with fixes and tweaks.
