Since last update the Echo Speaks lost the auth token every 1-2 days and I need to reauthenticate.
Someone more faced it?
I would also like the response to go back to the device it was asked from!
Thanks to the @zarthan for pointing to an app that will allow you to add auto-updates to the server without having to add me as a collaborator.
The Github app is called Pull
I added some basic steps to the documentation here:
https://tonesto7.github.io/echo-speaks-docs/updates/server_update/#automated_method
So does that make me a co-creator of the ES app?
Anyone else getting repeat announcements with the latest (and previous) version? I have a rule that announces when a lock is unlocked and I get repeats on several of my Echo devices.
I have looked all over to find a way to do this, but have not succeeded. Can anyone show me how to get Echo Speaks to play a sound (like a chime or a beep)?
https://tonesto7.github.io/echo-speaks-docs/devicesupport/commands/speech_commands/#playsoundbynamename
Please note that when initially launched you could use most of files that start with amzn_sfx_ but they seem to have been restricting them down to only the sounds supported by Alexa Routines
Unfortunately you can't play every sound in the effects library.
I would be happy if I could play any sound in the library, @tonesto7.
I just tried the ‘Ticking clock’ sound that Alexa’s have in their routines and got this.
What am I doing wrong?
maybe it's the capital T
send it as playSoundByName("ticking_clock")
Tried what you recommended. Didn’t work. Here it is:
Please keep trying to help, @tonesto7.
This would be really neat if it worked...
Don
Playing sound by name works for me.
Try using bells
I must be doing something fundamentally wrong. Whether I enter the string “bells” directly into the tile in the driver or include it in an action, no sound. Here is what I did:
Hoping someone can help me figure this out...
OK, figured it out.
Works great!
Getting the following errors which is slowing my hub:
Please what does it mean and how do I fix it?
@tonesto7, I'm getting repeat notifications on multiple Echo devices when my rule announces my lock being unlocked via code. This started happening 2 versions ago. Any ideas?
I receiving the same error. It started appearing a few days ago.
