[RELEASE] Echo Speaks v3 + Actions
RELEASE V4.0 BETA
We wanted to get this release out there for you guys to test.
Note
I've changed the file structure some so I recommend you use Hubitat Package Manager and select the new entry for Echo Speaks (Beta) to install the code.
I want to give a big thanks to his @nh.schottfam for all his work on this release.
  • [UPDATE] Reduced overhead and resource usage
  • [UPDATE] Add new echo devices
Echo Speaks App
  • [UPDATE] Optimizations
  • [UPDATE] Reduced accesses to AWS Alexa APIs by caching results for re-use
  • [UPDATE] Removed a lot of state and atomicState accesses
  • [UPDATE] Many JVM optimizations to reduce memory use in HE
  • [UPDATE] More use of async HTTP calls
  • [UPDATE] UI improvements
  • [UPDATE] Improved status reporting and descriptions
  • [UPDATE] Cleanup of use of local server deployments
  • [UPDATE] Improved cookie refresh operations (in conjunction with server updates)
  • [UPDATE] Fixes for conditions, restrictions handling, time-based conditions, and restrictions
  • [UPDATE] Updates for operation with HSM,
  • [ADDED] Restored Zone and Action duplications.
  • [UPDATE] Added support for new Echo devices
Echo Speaks Actions
  • [UPDATE] Integration with lock codes and security keypads, humidity sensors
  • [UPDATE] Ability to filter actions on specific security code usage
  • [UPDATE] Integration with webCoRE
  • [UPDATE] Ability to execute pistons
  • [UPDATE] Ability to trigger based on piston executions
Echo Speaks Zones
  • [UPDATE] Improved time handling and transitioning
  • [UPDATE] Improved UI
Echo Speaks Device
  • [UPDATE] Improved labeling for command inputs
  • [UPDATE] Less overhead
  • [NEW] Added new voiceCmdAsText() command to execute commands as if they are spoken to the device
Echo Speaks WebSocket
  • [UPDATE] Improved operations with WebSockets
