I've put together a driver for the Maestro. It's in this thread (to keep discussions organized )
https://community.hubitat.com/t/pre-release-device-driver-for-stelpro-maestro-thermostat-zigbee
Hello Philippe and company...
I have the z-wave version of your thermostat, STZW402+.
I am very new to Hubitat and have not yet found an adequate driver. Would your driver be hard to convert over to z-wave?
Thanks!
Bill
Hi Bill. Welcome to the Hubitat Community!
I would point you to the official SmartThings driver and start from there.
Work should be similar to what I had to do to port the Zigbee driver. I fiddled a bit to make it compatible with Hubitat, removed some superfluous code, and further more adjusted it to make it compatible with Hubitat's Google Home App.
However, since I know next to nothing about Z-Wave and I don't have that version of the device to test on, I won't take on the task of porting that driver. I wouldn't be much help. Maybe someone on the boards is up for it... Unless you're up to the challenge!
Hi Philippe,
Thanks for the quick reply.
Rather than the SmartThings driver, wouldn't your driver be a better place to start, with all the mods and corrections you've made?
I'll see if I can find some way to swap zigbee for z-wave.
Yeah, that should work. With the Hubitat Zigbee driver as a template, merge in Stelpro's Z-Wave code.
Good luck!
Any luck using this driver to create a Z-wave version? I have three of these Z-wave thermostats that I can't return. Arrrrg. Willing to provide any help I can. Thanks!
I'm using this driver and for the most part, it works. The trouble I'm noticing is there is a communication issue thru Alexa. It show the correct current temp, but the setpoint isn't working. If I ask alexa to change the setpoint, she says " sorry thermostat isn't responding, yet the setpoint does change. Any ideas?
