Thank you again for the incredibly fast turnaround. I will load it and test it this afternoon
Everything works great. THANK YOU! All set here.
Cool! I’ll merge it into the main code tomorrow. Glad it’s working!
Curious to know if other users of this app are still having success with the recent updates to HE? I am current to release 2.2.3.119 and finding my device drivers for this app will no longer interact with my HEOS speakers (I have 4). i.e. no info in the status panel on the right nor the Event logs. I have run numerous discoveries successfully (i.e. seeing the correct IPs for my speakers being detected) after deleting existing device drivers and even the App and no joy.
I am new to app so still learning its potential -- if only I could getting working again
Hmm it's working for me. When you click any of the commands in a device, do you get anything in the logs? Another thing to check, go to each speaker device and scroll down to the bottom. Can you confirm that exactly 1 speaker has master set to true?
Thanks for the pointer on what to look for Dom. Yes, that was the issue. None of my added devices contained 'master:true'. I performed numerous deletes of speaker devices and re-discoveries/additions. I have been unable to get all 4 of my devices to successfully add --- the last one on the list is simply never added. The debug logs are clean of error messages. My most recent test of choosing the first 3 devices on the list presented during discovery was successful i.e. the first one on the picklist of devices was made 'master: true' and the other two 'master:false' Config commands are successful on all of them.
P.S. I had many hit and miss additions prior to this i.e. situations where no device was added as 'master:true'.
P.P.S. Since my first post another HE release has come out: 2.2.3.132. All my this testing was completed on that release.
FYI: here is log excerpt. It is the device called 'Office' that won't add:
2020-08-24 09:34:45.315 pm debugreceived message from master: [[lineout:0, gid:-1702679353, serial:ACJG9170812606, ip:172.20.0.234, name:Foyer, pid:-1702679353, model:HEOS 1, version:1.562.236, network:wifi], [lineout:0, gid:-1702679353, serial:ACJG9170812605, ip:172.20.0.213, name:Office, pid:-1782855513, model:HEOS 1, version:1.562.236, network:wifi], [lineout:2, gid:-1702679353, ip:172.20.0.239, name:Family Room, pid:-576344799, model:HEOS Link, control:4, version:1.562.236, network:wifi], [lineout:0, gid:-1702679353, ip:172.20.0.211, name:Deck, pid:1368500551, model:HEOS Amp, version:1.562.236, network:wifi]]
app:10922020-08-24 09:34:39.626 pm debugDiscovering HEOS devices
Can you show an example of this please? I have tried to make this command work by typing in the name of the station and to no avial. Is there a syntax in which it has to be inputted as in order for it to be recognized? any example outputs of what this looks like would be greatly beneficial so I can move forward with my UX work here. Thanks
An example of what? Calling playTopResult?
does anyone have any idea if the latest HE version (2.2.4.141) works with this integration?
i installed the app and the driver, and have tried waiting patiently at the 'Please wait while your HEOS account information is validated...' screen while installing the app, but it never gets any further.
Debug logging is on and looking at the logs, the Temp HEOS Account Verifier never gets further than this;
dev:16112020-11-19 06:38:23.609 pm debugConnecting to HEOS
dev:16112020-11-19 06:38:23.608 pm debugverifying HEOS account
dev:16112020-11-19 06:38:23.566 pm debugInstalled with settings: [debugOutput:true]
and the Denon HEOS Integration app's logs don't show anything other than this:
app:15822020-11-19 06:48:39.170 pm debugDiscovering HEOS devices
anyone have any ideas as to what i may be doing wrong?
Confirmed, this is a Hubitat bug in 2.2.4.
@gopher.ny Please see this code which is a minimal sample to reproduce the problem. Create a virtual device using this driver and you will see two log messages:
DataValue is : yes
DataValue is now : null
getDataValue
does not appear to be working from within a runIn
metadata {
definition (name: "Buggy Driver", namespace: "dcm.heos", author: "dmeglio@gmail.com") {
def installed() {
updateDataValue("something","yes")
log.debug "DataValue is : ${getDataValue('something')}"
runIn(5,showDV)
def showDV() {
log.debug "DataValue is now : ${getDataValue('something')}"
Additionally the data section for the device does not show the value:
I suspect that will resolve it, if you give it a try and it works it will certainly prove my theory!
OK, your theory seems to have been correct...however, now that I've got it installed, it seems the 'play top result' button isn't working:
I've tried it for Amazon Music and Pandora as well as Soundcloud and it doesn't seem to want to do anything when I fill in the fields and hit the button.
Anything in the logs?
sorry forgot to look there first...one message saying that artist search isn't supported by soundcloud or amazon music (which may not be expected since your table lists it?), also got track search not supported by amazon music.....................and when i tried by track on soundcloud, it looks like it tried the search, picked the top result, and then something in the message wasn't valid:
dev:16062020-11-19 11:14:42.975 pm errorTrack search not supported by Amazon Music
dev:16062020-11-19 11:13:58.824 pm errorArtist search not supported by Amazon Music
dev:16062020-11-19 11:11:21.934 pm errorArtist search not supported by Soundcloud
dev:16062020-11-19 11:10:12.177 pm debugTelnet Message: [heos:[result:fail, message:eid=2&text=ID Not Valid&pid=null&sid=null&cid=null&mid=127261456&name=The Sound Of Silence (Simon %26 Garfunkel), command:browse/play_stream]]
dev:16062020-11-19 11:10:12.171 pm debugSending HEOS command: heos://browse/play_stream?pid=null&sid=null&cid=null&mid=127261456&name=The Sound Of Silence (Simon %26 Garfunkel)
dev:16062020-11-19 11:10:12.163 pm debugTelnet Message: [heos:[result:success, message:sid=9&search=sound of silence&scid=3&pid=-366443456&returned=100&count=197, command:browse/search], payload:[[container:no, artist:Daniel Banon, album:, image_url:https://i1.sndcdn.com/artworks-000066695100-89jqgb-t500x500.jpg, name:The Sound Of Silence (Simon %26 Garfunkel), mid:127261456, album_id:, type:song, playable:yes], [container:no, artist:Disturbed1, album:, image_url:https://i1.sndcdn.com/artworks-GwuffLiSfP7U-0-t500x500.jpg, name:The Sound of Silence, mid:256180873, album_id:, type:song, playable:yes], [container:no, artist:Kamikaze Karaoke, album:, image_url:https://i1.sndcdn.com/artworks-000154957802-ag1ap0-t500x500.jpg, name:Disturbed - Sound of Silence Live HD, mid:255905650, album_id:, type:song, playable:yes], [container:no, artist:Mostafa Adham 1, album:, image_url:https://i1.sndcdn.com/artworks-000048137462-fypuir-t500x500.jpg, name:Kenny G - Saxophone - The Sound of Silence, mid:92389400, album_id:, type:song, playable:yes], [container:no, artist:SIMON&GARFUNKELbyBookends, album:, image_url:https://i1.sndcdn.com/avatars-000218928153-2h9szr-t500x500.jpg, name:The Sound Of Silence, mid:69362728, album_id:, type:song, playable:yes], [container:no, artist:Rene R. (Official), album:, image_url:https://i1.sndcdn.com/artworks-000215382593-l2scs9-t500x500.jpg, name:Sound Of Silence, mid:315193854, album_id:, type:song, playable:yes], [container:no, artist:Millesim, album:, image_url:https://i1.sndcdn.com/artworks-000140888441-iry1vj-t500x500.jpg, name:Millesim - The Sound Of Silence (feat. Lyon Hart), mid:186042299, album_id:, type:song, playable:yes], [container:no, artist:TheDooo, album:, image_url:https://i1.sndcdn.com/artworks-bdJmBMJi5BETlmpC-Psqfig-t500x500.jpg, name:Sound Of Silence Cover, mid:584508954, album_id:, type:song, playable:yes], [container:no, artist:Sounds of the Sixties, album:, image_url:https://i1.sndcdn.com/artworks-000089941119-ufiegw-t500x500.jpg, name:Sound Of Silence, mid:166034948, album_id:, type:song, playable:yes], [container:no, artist:Y.A.S OFFICIAL ®ï¸, album:, image_url:https://i1.sndcdn.com/artworks-000635142217-xe3ah3-t500x500.jpg, name:Sound Of Silence, mid:710764681, album_id:, type:song, playable:yes], [container:no, artist:Oliver Tank, album:, image_url:https://i1.sndcdn.com/artworks-000053635161-u0a21d-t500x500.jpg, name:Sound Of Silence feat. Fawn Myers, mid:102353932, album_id:, type:song, playable:yes], [container:no, artist:Jay-Lounge, album:, image_url:https://i1.sndcdn.com/artworks-000464481798-1m6jup-t500x500.jpg, name:Sound Of Silence, mid:551107005, album_id:, type:song, playable:yes], [container:no, artist:Cailyn cCook, album:, image_url:https://i1.sndcdn.com/artworks-000159477300-3iayaa-t500x500.jpg, name:Disturbed "The Sound Of Silence" Live, mid:260463273, album_id:, type:song, playable:yes], [container:no, artist:duoCosy, album:, image_url:https://i1.sndcdn.com/artworks-000072054129-401q8d-t500x500.jpg, name:Sound Of Silence (Simon And Garfunkel), mid:136993530, album_id:, type:song, playable:yes], [container:no, artist:KairoRocket, album:, image_url:https://i1.sndcdn.com/avatars-000631875060-50u2oj-t500x500.jpg, name:Sound Of Silence, mid:631403859, album_id:, type:song, playable:yes], [container:no, artist:Devachellun, album:, image_url:https://a1.sndcdn.com/images/default_avatar_t500x500.png, name:Sound Of Silence., mid:171714407, album_id:, type:song, playable:yes], [container:no, artist:Vexati0n, album:, image_url:https://i1.sndcdn.com/artworks-000385115451-q5832z-t500x500.jpg, name:SOUND OF SILENCE, mid:481998354, album_id:, type:song, playable:yes], [container:no, artist:The Golden Pony VIP, album:, image_url:https://i1.sndcdn.com/artworks-000150795111-6owqnd-t500x500.jpg, name:Simon %26 Garfunkel - Sound Of Silence (The Golden Pony Remix), mid:245001229, album_id:, type:song, playable:yes], [container:no, artist:Eren Kocer, album:, image_url:https://i1.sndcdn.com/avatars-000203378593-myy6ny-t500x500.jpg, name:Sound Of Silence, mid:148349172, album_id:, type:song, playable:yes], [container:no, artist:Ontario Musique, album:, image_url:https://i1.sndcdn.com/artworks-000011316333-tjcr3f-t500x500.jpg, name:Sound Of Silence, mid:22862248, album_id:, type:song, playable:yes], [container:no, artist:pouyanikpour, album:, image_url:https://i1.sndcdn.com/artworks-000045363922-9bxeza-t500x500.jpg, name:Sound Of Silence, mid:26451397, album_id:, type:song, playable:yes], [container:no, artist:Chuck Aaron, album:, image_url:https://i1.sndcdn.com/avatars-000290186897-atx521-t500x500.jpg, name:Sound Of Silence, mid:206320339, album_id:, type:song, playable:yes], [container:no, artist:Chakira, album:, image_url:https://i1.sndcdn.com/artworks-I5FIR2wp6g1m-0-t500x500.jpg, name:Sound of silence, mid:745587067, album_id:, type:song, playable:yes], [container:no, artist:cyan sunday, album:, image_url:https://i1.sndcdn.com/artworks-000187396675-16qqbt-t500x500.jpg, name:Sound Of Silence, mid:286676570, album_id:, type:song, playable:yes], [container:no, artist:Senscapes, album:, image_url:https://i1.sndcdn.com/artworks-zvPUG79Hz0npngeX-LMcawA-t500x500.jpg, name:Sound of Silence, mid:867052138, album_id:, type:song, playable:yes], [container:no, artist:Tristan Carter, album:, image_url:https://i1.sndcdn.com/avatars-000803183389-8dcsot-t500x500.jpg, name:Sound of Silence, mid:798734605, album_id:, type:song, playable:yes], [container:no, artist:Blue birds, album:, image_url:https://i1.sndcdn.com/artworks-000228724755-ikluk1-t500x500.jpg, name:Sound Of Silence, mid:328343652, album_id:, type:song, playable:yes], [container:no, artist:chickhabitmusic, album:, image_url:https://i1.sndcdn.com/artworks-000031252791-ybsk1c-t500x500.jpg, name:Sound of Silence, mid:61630819, album_id:, type:song, playable:yes], [container:no, artist:DnB, album:, image_url:https://i1.sndcdn.com/artworks-000219871417-3ydjjq-t500x500.jpg, name:Sound Of Silence, mid:319671002, album_id:, type:song, playable:yes], [container:no, artist:AlexanderNFK, album:, image_url:https://i1.sndcdn.com/avatars-000012082559-tigzkq-t500x500.jpg, name:Sound of silence, mid:85044850, album_id:, type:song, playable:yes], [container:no, artist:2B-Tim&Robbert, album:, image_url:https://i1.sndcdn.com/artworks-000051368616-fiun46-t500x500.jpg, name:Sound Of Silence, mid:98249141, album_id:, type:song, playable:yes], [container:no, artist:Emil de Waal, album:, image_url:https://i1.sndcdn.com/avatars-000003029754-xi0eug-t500x500.jpg, name:Sound Of Silence, mid:178711065, album_id:, type:song, playable:yes], [container:no, artist:Hanville Sound, album:, image_url:https://a1.sndcdn.com/images/default_avatar_t500x500.png, name:Sound Of Silence, mid:334397953, album_id:, type:song, playable:yes], [container:no, artist:haileyelise, album:, image_url:https://a1.sndcdn.com/images/default_avatar_t500x500.png, name:Sound of Silence, mid:96225356, album_id:, type:song, playable:yes], [container:no, artist:Ivan van der Merwe, album:, image_url:https://i1.sndcdn.com/artworks-k7sBwkr4ooV2dIzt-VJOaUQ-t500x500.jpg, name:Sound Of Silence, mid:866478445, album_id:, type:song, playable:yes], [container:no, artist:Rudy Cash, album:, image_url:https://i1.sndcdn.com/avatars-000177258260-2p2253-t500x500.jpg, name:Sound of Silence, mid:273935512, album_id:, type:song, playable:yes], [container:no, artist:Timothy Junior Sappa, album:, image_url:https://i1.sndcdn.com/artworks-000145416979-woa2q0-t500x500.jpg, name:Sound of Silence, mid:244854967, album_id:, type:song, playable:yes], [container:no, artist:LeeLa9**, album:, image_url:https://i1.sndcdn.com/artworks-000010713642-yu3z08-t500x500.jpg, name:Sound Of Silence, mid:21713014, album_id:, type:song, playable:yes], [container:no, artist:Daniel Waites, album:, image_url:https://i1.sndcdn.com/avatars-000009627157-9s3hh7-t500x500.jpg, name:Sound of silence, mid:35495667, album_id:, type:song, playable:yes], [container:no, artist:Kenny Bucek, album:, image_url:https://i1.sndcdn.com/artworks-000283369205-8p8ik9-t500x500.jpg, name:Sound Of Silence, mid:381746342, album_id:, type:song, playable:yes], [container:no, artist:Alex Salieri, album:, image_url:https://i1.sndcdn.com/artworks-000140180975-qizuio-t500x500.jpg, name:Sound Of Silence, mid:238325582, album_id:, type:song, playable:yes], [container:no, artist:Snafu, album:, image_url:https://i1.sndcdn.com/avatars-000239388605-3p7zfq-t500x500.jpg, name:Sound Of Silence, mid:273731172, album_id:, type:song, playable:yes], [container:no, artist:AD UNDAS, album:, image_url:https://i1.sndcdn.com/avatars-000041407339-dspv5v-t500x500.jpg, name:Sound Of Silence, mid:330205083, album_id:, type:song, playable:yes], [container:no, artist:2ndspring.ch, album:, image_url:https://a1.sndcdn.com/images/default_avatar_t500x500.png, name:Sound - Of - Silence, mid:175493609, album_id:, type:song, playable:yes], [container:no, artist:Syd708, album:, image_url:https://a1.sndcdn.com/images/default_avatar_t500x500.png, name:Sound Of Silence, mid:99445144, album_id:, type:song, playable:yes], [container:no, artist:Daniel Gunn, album:, image_url:https://i1.sndcdn.com/artworks-iniVnU8KoUdjwJDT-EQ9U8w-t500x500.jpg, name:Sound of Silence, mid:868298815, album_id:, type:song, playable:yes], [container:no, artist:Susan Wong, album:, image_url:https://i1.sndcdn.com/artworks-lgaXLe4razpy-0-t500x500.jpg, name:Sound Of Silence, mid:325717806, album_id:, type:song, playable:yes], [container:no, artist:LINZ AG Musik, album:, image_url:https://i1.sndcdn.com/artworks-000438312759-axnqw9-t500x500.jpg, name:Sound of Silence, mid:528505338, album_id:, type:song, playable:yes], [container:no, artist:Tobias Winter 7, album:, image_url:https://i1.sndcdn.com/avatars-000049419213-rxmzw9-t500x500.jpg, name:Sound Of Silence, mid:103968601, album_id:, type:song, playable:yes], [container:no, artist:Joseph Bowand, album:, image_url:https://i1.sndcdn.com/artworks-000611817127-5o4cpf-t500x500.jpg, name:Sound of silence, mid:695111914, album_id:, type:song, playable:yes], [container:no, artist:Julianf, album:, image_url:https://i1.sndcdn.com/artworks-000170147744-90odjz-t500x500.jpg, name:Sound Of Silence, mid:272222914, album_id:, type:song, playable:yes], [container:no, artist:Ãyvind Einen, album:, image_url:https://i1.sndcdn.com/artworks-YBNd8KqFgkOYspta-gDykwA-t500x500.jpg, name:Sound of Silence, mid:793068085, album_id:, type:song, playable:yes], [container:no, artist:Max Embers, album:, image_url:https://i1.sndcdn.com/artworks-IvzWpEvOpkHt-0-t500x500.jpg, name:Sound Of Silence, mid:694394335, album_id:, type:song, playable:yes], [container:no, artist:IkePitts, album:, image_url:https://i1.sndcdn.com/avatars-000150150594-onbn1v-t500x500.jpg, name:Sound of Silence, mid:321828320, album_id:, type:song, playable:yes], [container:no, artist:chunky beltones, album:, image_url:https://i1.sndcdn.com/avatars-000269125348-6obtju-t500x500.jpg, name:SOUND OF SILENCE, mid:285814219, album_id:, type:song, playable:yes], [container:no, artist:Abigail Harmon, album:, image_url:https://i1.sndcdn.com/artworks-000149464903-1jrtqe-t500x500.jpg, name:Sound Of Silence, mid:249959793, album_id:, type:song, playable:yes], [container:no, artist:rosealine, album:, image_url:https://a1.sndcdn.com/images/default_avatar_t500x500.png, name:Sound Of Silence, mid:142877563, album_id:, type:song, playable:yes], [container:no, artist:Colerain High School Vocal Music, album:, image_url:https://i1.sndcdn.com/avatars-000342183223-zj2wj4-t500x500.jpg, name:Sound of Silence, mid:659505668, album_id:, type:song, playable:yes], [container:no, artist:lisahil, album:, image_url:https://i1.sndcdn.com/artworks-000088182252-o6ow0x-t500x500.jpg, name:Sound Of Silence, mid:163310109, album_id:, type:song, playable:yes], [container:no, artist:Zonhoven House of Arts, album:, image_url:https://i1.sndcdn.com/artworks-000416156916-4zdpjs-t500x500.jpg, name:Sound of Silence., mid:510788364, album_id:, type:song, playable:yes], [container:no, artist:markandmarsha, album:, image_url:https://i1.sndcdn.com/avatars-000161529882-e4ai2r-t500x500.jpg, name:Sound Of Silence, mid:218963162, album_id:, type:song, playable:yes], [container:no, artist:safetybearmofo, album:, image_url:https://i1.sndcdn.com/avatars-000006262855-77f1xn-t500x500.jpg, name:Sound of Silence, mid:24403648, album_id:, type:song, playable:yes], [container:no, artist:10.5mmm, album:, image_url:https://i1.sndcdn.com/artworks-000576518618-ddfjjh-t500x500.jpg, name:Sound Of Silence, mid:660075215, album_id:, type:song, playable:yes], [container:no, artist:Sandra Nascimento, album:, image_url:https://i1.sndcdn.com/artworks-000410912040-9yw993-t500x500.jpg, name:Sound of Silence, mid:505164612, album_id:, type:song, playable:yes], [container:no, artist:Emilio Gómez, album:, image_url:https://i1.sndcdn.com/avatars-000479782296-jn4en2-t500x500.jpg, name:Sound Of Silence, mid:478076817, album_id:, type:song, playable:yes], [container:no, artist:arR'n'Jment studio, album:, image_url:https://i1.sndcdn.com/avatars-000134895373-0k0on6-t500x500.jpg, name:Sound Of Silence, mid:165627205, album_id:, type:song, playable:yes], [container:no, artist:Gucci Graham, album:, image_url:https://i1.sndcdn.com/artworks-000263568359-4dbovr-t500x500.jpg, name:Sound of Silence, mid:363336398, album_id:, type:song, playable:yes], [container:no, artist:case.jessie, album:, image_url:https://a1.sndcdn.com/images/default_avatar_t500x500.png, name:Sound of Silence, mid:121490499, album_id:, type:song, playable:yes], [container:no, artist:Indy Mat-Sir, album:, image_url:https://i1.sndcdn.com/artworks-000072061720-1fw2zw-t500x500.jpg, name:Sound of Silence, mid:137007014, album_id:, type:song, playable:yes], [container:no, artist:S-Fen Eng, album:, image_url:https://i1.sndcdn.com/avatars-000109771528-zu0r3n-t500x500.jpg, name:Sound Of Silence, mid:172585556, album_id:, type:song, playable:yes], [container:no, artist:Steel559, album:, image_url:https://i1.sndcdn.com/artworks-000011278517-1luq3r-t500x500.jpg, name:Sound of Silence, mid:22788355, album_id:, type:song, playable:yes], [container:no, artist:Under The Stairs, album:, image_url:https://i1.sndcdn.com/artworks-000606465496-4l1i3q-t500x500.jpg, name:Sound Of Silence, mid:689783206, album_id:, type:song, playable:yes], [container:no, artist:Björn Roth, album:, image_url:https://i1.sndcdn.com/avatars-000299313506-xf3qa0-t500x500.jpg, name:Sound Of Silence, mid:310376812, album_id:, type:song, playable:yes], [container:no, artist:shawn hughes, album:, image_url:https://i1.sndcdn.com/avatars-000916080376-pw6lta-t500x500.jpg, name:Sound of silence, mid:929029624, album_id:, type:song, playable:yes], [container:no, artist:cc onu, album:, image_url:https://i1.sndcdn.com/artworks-OwDCwW4dJIEyB9Sl-WR9xhw-t500x500.jpg, name:Sound of Silence, mid:812462161, album_id:, type:song, playable:yes], [container:no, artist:Gabi, album:, image_url:https://i1.sndcdn.com/artworks-acVXhdLt5Jvu-0-t500x500.jpg, name:Sound Of Silence, mid:854991220, album_id:, type:song, playable:yes], [container:no, artist:EshantManghnani, album:, image_url:https://a1.sndcdn.com/images/default_avatar_t500x500.png, name:Sound of Silence, mid:158084259, album_id:, type:song, playable:yes], [container:no, artist:AcquaZüri, album:, image_url:https://i1.sndcdn.com/artworks-000430769553-tloc6j-t500x500.jpg, name:Sound of Silence, mid:521917008, album_id:, type:song, playable:yes], [container:no, artist:Alondra Galopa, album:, image_url:https://i1.sndcdn.com/artworks-cQvUX0uWoxmH-0-t500x500.jpg, name:Sound Of Silence, mid:827620555, album_id:, type:song, playable:yes], [container:no, artist:Nobody Knows, album:, image_url:https://i1.sndcdn.com/avatars-000509117619-sghvr4-t500x500.jpg, name:Sound - Of - Silence, mid:619930458, album_id:, type:song, playable:yes], [container:no, artist:Sean Zhang, album:, image_url:https://i1.sndcdn.com/avatars-000359887244-58xcn3-t500x500.jpg, name:Sound Of Silence, mid:364401632, album_id:, type:song, playable:yes], [container:no, artist:tharsa, album:, image_url:https://a1.sndcdn.com/images/default_avatar_t500x500.png, name:sound of silence, mid:450489192, album_id:, type:song, playable:yes], [container:no, artist:eragon748, album:, image_url:https://i1.sndcdn.com/artworks-000406472889-8g48i1-t500x500.jpg, name:Sound Of Silence, mid:500812587, album_id:, type:song, playable:yes], [container:no, artist:Olivier Morency, album:, image_url:https://i1.sndcdn.com/avatars-000029014659-ittg5h-t500x500.jpg, name:Sound of silence, mid:71918392, album_id:, type:song, playable:yes], [container:no, artist:AaronZhao, album:, image_url:https://i1.sndcdn.com/avatars-000740895973-pequdh-t500x500.jpg, name:Sound Of Silence, mid:729264670, album_id:, type:song, playable:yes], [container:no, artist:ribka12, album:, image_url:https://a1.sndcdn.com/images/default_avatar_t500x500.png, name:Sound Of Silence, mid:128003654, album_id:, type:song, playable:yes], [container:no, artist:Zhijun Tan, album:, image_url:https://i1.sndcdn.com/artworks-000246063904-xw51no-t500x500.jpg, name:Sound Of Silence, mid:345826987, album_id:, type:song, playable:yes], [container:no, artist:Andy Falck, album:, image_url:https://i1.sndcdn.com/artworks-000409568832-zs79wo-t500x500.jpg, name:Sound of silence, mid:503691201, album_id:, type:song, playable:yes], [container:no, artist:Nicki Kerns, album:, image_url:https://i1.sndcdn.com/avatars-000631972590-c08pbu-t500x500.jpg, name:Sound Of Silence, mid:626113806, album_id:, type:song, playable:yes], [container:no, artist:Sound of Silence, album:, image_url:https://i1.sndcdn.com/artworks-000099033575-997m4n-t500x500.jpg, name:Sound of Silence, mid:179708324, album_id:, type:song, playable:yes], [container:no, artist:SauwassVoice, album:, image_url:https://a1.sndcdn.com/images/default_avatar_t500x500.png, name:Sound Of Silence, mid:527868924, album_id:, type:song, playable:yes], [container:no, artist:WhinterTime, album:, image_url:https://i1.sndcdn.com/artworks-000159035465-42g4d5-t500x500.jpg, name:Sound Of Silence, mid:259996118, album_id:, type:song, playable:yes], [container:no, artist:Joeyjoejoe, album:, image_url:https://i1.sndcdn.com/artworks-000297005478-9bdrvi-t500x500.jpg, name:Sound of Silence, mid:394113768, album_id:, type:song, playable:yes], [container:no, artist:Krissy Chrome, album:, image_url:https://i1.sndcdn.com/artworks-000487171824-v7kc4r-t500x500.jpg, name:sound of silence., mid:573851007, album_id:, type:song, playable:yes], [container:no, artist:Tylerflint95, album:, image_url:https://i1.sndcdn.com/artworks-000316889580-ajsrx2-t500x500.jpg, name:Sound of Silence, mid:413855115, album_id:, type:song, playable:yes], [container:no, artist:emyemyemyy, album:, image_url:https://i1.sndcdn.com/artworks-000187397640-kt32r0-t500x500.jpg, name:Sound Of Silence, mid:286846450, album_id:, type:song, playable:yes], [container:no, artist:ChristopherAlexander, album:, image_url:https://i1.sndcdn.com/artworks-000017298148-adkhxo-t500x500.jpg, name:Sound of Silence, mid:34463716, album_id:, type:song, playable:yes], [container:no, artist:Native American Flute, album:, image_url:https://i1.sndcdn.com/artworks-gK2wyBWINU9f-0-t500x500.jpg, name:Sound of Silence, mid:704794873, album_id:, type:song, playable:yes], [container:no, artist:stucon, album:, image_url:https://i1.sndcdn.com/artworks-sjLNKEgVRsYUa0zO-6osNhA-t500x500.jpg, name:Sound of Silence, mid:819133453, album_id:, type:song, playable:yes], [container:no, artist:La Malle Aux Songs, album:, image_url:https://i1.sndcdn.com/avatars-000104310210-xfrhgt-t500x500.jpg, name:Sound Of Silence, mid:261962543, album_id:, type:song, playable:yes]]]
dev:16062020-11-19 11:10:05.757 pm debugTelnet Message: [heos:[result:success, message:command under process&sid=9&search=sound of silence&scid=3&pid=-366443456, command:browse/search]]
dev:16062020-11-19 11:10:05.742 pm debugSending HEOS command: heos://browse/search?sid=9&search=sound of silence&scid=3&pid=-366443456
I’ve never used SoundCloud before so I’ll have to take a look.
which others have you tested with? i tried to scroll up through the thread and only saw stuff about pandora, and spotify not being supported?
GitHub - dcmeglio/hubitat-heos Explains what the HEOS api supports. I’ve tested pandora, iheartradio, and Amazon since those are the ones I have accounts for. You are correct though, Denon does not support Spotify via the api.
Correct. Check the table I listed. Those are not supported by Amazon. Only station and playlist are supported by Amazon.
On it. The fix will be in either next released version or the one after, but either way it has priority.
P.S. It just struck me that 100 years ago, phrase "buggy driver" as well as both words in it would mean something entirely different.
