I think I got it working..
Python did not update. Could someone step me through or provide a link on how to update it to 3.4?
O/S: Raspbian stretch version 9.
I have CATT working now that I downloaded version 0.5.6. CATT works fine in RPi (Ran a test). I get an error when using HE. What should I look for? Thanks
2019-11-10 06:11:47.512 pm [debug](http://MY HE IP ADDRESS/device/edit/258)parse Error: No such command "cast_site".
[dev:258](http://MY HE IP ADDRESS/logs#dev258)2019-11-10 06:11:47.492 pm debugparse Usage: catt [OPTIONS] COMMAND [ARGS]...
Please post a debug log (not just one line). I cannot track an issue without seeing what let up to the error.
Bryan,
What I replied enough info?
Yes, thanks. I just need time to test. I've added it to my list, will get to it soon.
Thank you.. No hurry
You got me stumped. I hadn't set this app back up on my second hub yet, so I just went through and installed it from scratch (pi was already setup from before). Worked perfect.
Couple of notes:
- Be sure you have all 3 components installed in Hubitat - parent, child and driver
- Looking at your log, the URL for the dashboard is incomplete. I did try what you had there and all it does is make the Google hub go 'bing bong' but doesn't display anything but also doesn't cause an error.
-- Link should be something like: http://192.168.7.91/apps/api/123/dashboard/123?access_token=1234-1234-1234-1234-1234&local=true on
So I just need to change:
http://myIPaddress/apps/api/my#/dashboard/my#?access_token=mytokenaddress&local=true on
Yes, Just bring up any dashboard in your browser and copy the complete URL
Browser doesn't show all that info
can you run the url from RPi using cast?
If you use Chrome it does.
Never tried. Start small and try to just sent something like google.com and see if that will come up. Once you know that your rPI is setup correctly then move on to this app.
I have Chrome 78.0.3904.97 and it does not.
I was unaware of this project until I read your post. Thank you - it finally provides me with the ability to control my Sonos when I'm away from home!
Bryan, It is in CATT for RPi. Catt doesn't see the cast_site command. I get an error. I can cast a youtube video just fine. Sent a message to Stavros to assist. Thanks for your assistance.
Please go into your 'Send to Hub with Catt' device and see what the attribute 'telnet' has for a value. If it's set up correctly then it should be 'connected'.
ie.
telnet : Connected
It is connected. I was trying cast_site in RPi with the error.
I really have no idea what you mean by this. I can't help you with the rPI side of things.
If you want to show me the device made with the driver that says connected and then show me show screenshots of how you have the app setup, maybe something will pop out as to what is going on.
