[RELEASE] Bulk Device Parent
Driver used to create bulk virtual child switch and dimmer devices easily. Handy for hub load testing and other development work.
NOTE: Not really useful for end users - the child devices don't do anything - they are virtual and connected to nothing physical.
USE:
  • Enter # of devices to create (99 max or each type) and click button. Child devices will be created.
  • Enter zero for the number to create to delete all child devices of that type.
  • SwitchOn/SwitchOff turns on/off ALL child switch devices at once.
  • DimmerOn/DimmerOff turns on/off ALL child dimmer devices at once.
  • DimmerSetLevel sets level on ALL child dimmer devices at once.
  • On/Off/Level Randomizers. Generate random values (on, off, level%) at defined frequency, for defined period of time.
TO-DO:
  • May add more device types. Haven't really decided.
  • May add Will likely add a value randomizer to dimmer level values to generate a continuous stream of "data" from the child devices
  • May add Will likely add an on/off randomizer for switches or dimmers to generate a continuous stream of "data" from the child devices
VERSIONS:
  • V1.0.0 (01/14/2021) - Initial Version. Supports switches and dimmers as child devices.
  • V2.0.0 (01/14/2021) - Added on/off/level randomizers
https://raw.githubusercontent.com/Botched1/Hubitat/master/Drivers/Bulk%20Device%20Parent/Bulk%20Device%20Parent.groovy
