*** BPTWorld apps are no longer being developed or maintained. Thanks ***
Introducing 'Averaging Plus'
Average just about anything. Get notifications based on Set points.
- Select groups of devices that share a common attribute
- Devices do not have to be the same type!
- Adjustable time between averages
- Selectable High and Low set points
- Selectable Reference device to calculate Delta value
- Get notifications and/or turn a switch on when set point is reached
- All speech requires 'Follow Me'
- Automatically creates data device if needed
- Parent/Child App structure
- Create as many child apps as needed
Apps can be found on my GitHub or by using Bundle Manager.
When reporting problems...
- Be sure you are on the latest version. I won't troubleshoot an older version.
- Turn on debug and screenshot the issue happening in the log. One line or just the error doesn't cut it. I need a log.
- Post the screenshot of the log with an explanation of the problem.
