I seem to like writing my own drivers for devices I use, so here's the latest one from the AOne Aurora range.
These are great because they're designed to fit a standard UK dimmer module size on the back of whatever decorative faceplate you want. They also act as decent repeaters.
Installation
Search for the keyword "Aurora" on Hubitat Package Manager and you should see "Aurora Drivers from BirdsLikeWires". Requires HPM v1.8.7 or later. Or install manually from the link below.
- Aurora AU-A1ZB2WDM Dimmer - Import URL: RAW
All the features work, including turning the little blue indicator on or off. The dimmer doesn't remember this setting if it loses power, but you could make a little rule to solve that.
