NOTE: Upcoming platform release 2.5.3 will include built-in TV Remote integrations, including for Android/Google TVs. This community integration may continue to be maintained if there is both value and interest.
Android TV Remote is a driver for Google TV and Android TV devices. It talks to the TV directly with the protocol Google's TV remote app uses.
- Power:
onandoff.switchfollows the power state the TV reports. - Keys:
sendKeytakes any Android key name (HOME,BACK,DPAD_UP,LAST_CHANNEL,TV_INPUT_HDMI_1, ...), with or without theKEYCODE_prefix, or an Android key code. For the digit keys useKEYCODE_0toKEYCODE_9: a bare number is a key code. - Text (experimental):
sendTexttypes into the text field that has focus on the TV. - Apps:
launchAppopens an app from its deep link, such ashttps://www.youtube.com.currentAppshows the app in the foreground and updates on every change. - Volume:
volumeUp,volumeDown,mute,unmuteandsetVolume. - Connection: the driver finds the TV on the network, and follows it to a new IP address. It reconnects on its own after the TV drops the session, goes quiet or loses power. Pairing survives a TV power cut.
Status
NOTE: status changed from BETA to RELEASE 2026/11/07
Several TV sets and set-top boxes have been tested.
Tested TVs and boxes
Tester reports in this topic:
- Google TV Streamer
- NVIDIA SHIELD Android TV (four reports)
- Sony BRAVIA 4K AE3
- SEI Robotics FRC1 (Eastlink box)
- TCL Smart TV Pro (Google TV): stays reachable when off only with Energy Modes = Increased
- onn. 4K Plus Streaming
- Technicolor EBOX TV
In use, no tester report yet: Hisense 50H5BG
Mock TV profiles (the driver is tested against each before a release): every model above (TCL in both energy modes), plus models built from Home Assistant reports:
- Chromecast with Google TV
- Sony BRAVIA 4K VH2
- TiVo Stream 4K
- Xiaomi Mi TV Stick
- Freebox Player POP
Run the Android TV Remote Tester on your TV and post the report here: each new model becomes a profile.
Known limits:
- Set-top boxes that pass volume to the TV over HDMI-CEC never report a volume level. The volume keys work there, but
setVolumecan't. - Package names (
com.google.android.youtube.tv) no longer launch apps: since a Google Play update in August 2026, TVs refuse themarket://launch?id=link a package name is sent as. Use a link the app handles; the README lists links for common apps. - After a wrong pairing code, press Connect to resume the session.
- If the TV loses power and comes back with a different IP address, the hub may not find it until the hub restarts (a platform issue, reported). A DHCP reservation rules that out.
- Some TVs leave the network when turned off, so the driver can't turn them back on; the switch shows
offand the driver reconnects once the TV is on. On a TCL Google TV, Settings > System > Power & Energy > Energy Modes = Increased keeps it reachable.
Install
With Hubitat Package Manager: search for Android TV Remote.
By hand: in Drivers Code, choose New Driver, then Import, and paste https://raw.githubusercontent.com/hubitrep/hubitat/refs/heads/main/androidtv/AndroidTVRemote.groovy. Tested on platform versions 2.5.2.x and 2.5.3.x.
Setup
"The TV" here is the device running Android TV or Google TV: with a box such as an NVIDIA Shield or a Chromecast, the box, not the screen it plugs into.
- Add a virtual device with the Android TV Remote driver and click Save Preferences, leaving the IP address blank. The driver finds the TV on the network and fills in its address; reload the page after a few seconds to see it. With several TVs, a TV list appears: pick one and save again.
- Press Start Pairing. A 6-character code appears on the TV.
- Enter it with Submit Pairing Code. The device shows
pairing: pairedand connects.
If the driver doesn't find the TV, the log says so. The TV must be on and on the same network as the hub; the search doesn't cross VLANs or subnets unless the router repeats mDNS. In that case, enter the TV's IP address instead, and give the TV a fixed address (a DHCP reservation in your router), since the driver can't follow it to a new one without the search. Find TVs searches again.
After a hub restore or migration, the driver asks you to pair again.
Help wanted: test it on your TV
The package includes an optional app, Android TV Remote Tester, that runs the driver through a fixed set of tests and reports where your TV behaves differently from what the driver expects. Install it with HPM (it is an optional component), or import https://raw.githubusercontent.com/hubitrep/hubitat/refs/heads/main/androidtv/tests/AndroidTVRemoteTester.groovy in Apps Code.
- Add the app, select your Android TV Remote device and click Run.
- The default tests take about 3 minutes and change what is on the screen. They include a Discovery test: whether the TV announces itself on the network, and whether it still does while off.
- Optional tests cover a long standby, a wrong pairing code (shows a pairing dialog on the TV) and a power cut (select the smart plug that feeds the TV; the app turns it off for 30 seconds).
- Copy the report from the app page into a reply here, with your TV's make and model.
Reports from TVs with Google TV built in (e.g. Hisense), set-top boxes such as Chromecast with Google TV, Philips, Xiaomi and Fire TV-class would help the most.
Documentation: README
Questions, bugs and reports are welcome in this thread.
