[RELEASE] Alexa Device Alert Monitor
Hubitat device monitoring into Alexa announcements - NO TTS device required!
What It Does
Creates virtual contact sensors that can trigger Alexa routine announcements when your doors, locks, or lights are left open/unlocked/on.
Example: Garage door left open for 30 minutes → Virtual contact opens → Alexa announces "Garage door has been left open" < Repeats now for (x) amount of times.
AI Discusses App. : https://www.youtube.com/watch?v=7MpPEkd8aq0
Requirements
- Hubitat Elevation hub
- Amazon Echo devices
- Amazon Echo Skill app configured in Hubitat
- Virtual devices created by the app (automatic)
Key Features
Individual Device Monitors
Monitor specific devices with custom delays
- Added Repeat Feature - Allows app to repeat notifications for alerts.
- Each device gets its own virtual contact sensor
- Perfect for specific announcements - "Front door is unlocked" or "Garage door 2 is open"
- Added Separate Repeat Interval - Introduced a "Repeat Interval" input (1-60 mins, default 5) for individual monitors, allowing repeats independent of the initial delay (0 for instant alerts).
- Enabled Repeats for Zero Delay - Modified repeat logic to work with delay = 0, scheduling repeats based on the new "Repeat Interval" instead of the initial delay.
Group Monitors
Monitor multiple devices as one group
- Example: 3 garage doors → One alert if ANY is open
- Simplifies monitoring similar devices
- Added Group Name - Allows you to configure the group name.
- Added Separate Repeat Interval - Introduced a "Repeat Interval" input (1-60 mins, default 5) for group monitors, allowing repeats independent of the initial delay (0 for instant alerts).
- Fixed Group Monitor log error. 3.3.7
Smart Delays (0-60 minutes)
- 0 minutes = Immediate alert when device changes state
- 30 minutes = Wait before alerting (great for garage doors)
- Auto-cancellation = If you fix it before the delay expires, no alert!
- Added Repeat Feature = Allows app to repeat notifications for alerts.
Master Status Check
Press a button to check ALL monitored devices at once
- Creates separate contacts for each device type (Contacts/Locks/Lights)
- Perfect for bedtime or "leaving house" routines
- Each type opens only if that category has issues
Enable/Disable Monitors
Pause monitors without deleting settings
- Great for seasonal use (disable garage alerts in winter)
- Easy testing and troubleshooting
Auto-Naming & Customization
- Auto-generates sensible device names
- All devices prefixed with "V-ADAM" for easy identification
- Customize names when you need multiple groups
Mode Restrictions
Only alert in specific modes (Away, Night, etc.)
Installation
1. Install App Code
- Go to Apps Code → + New App
- Paste the app code
- Click Save
2. Create App Instance
- Go to Apps → Add User App
- Select "Alexa Device Alert Monitor"
- Click Done
3. Configure Monitors
Individual Monitor Example:
- Device: Front Door Lock
- Type: Lock
- Delay: 0 minutes (immediate)
- Creates: "V-ADAM - Lock Open - Front Door Alert"
Group Monitor Example:
- Devices: All 3 garage door contacts
- Type: Contact Sensor
- Delay: 30 minutes
- Creates: "V-ADAM - Any Garage Door Open Alert"
4. Expose to Alexa
- Open Amazon Echo Skill app in Hubitat
- Scroll to alexaDevices section
- Select all V-ADAM contacts
- Click Done
5. Create Alexa Routines
Example Routine:
- When: "V-ADAM - Lock Open - Front Door Alert" opens
- Then: Alexa says "Front door is unlocked"
FAQ
Q: Why contact sensors instead of switches? A: Alexa routines work MUCH better with contact sensor triggers. Switches often don't show up or are unreliable in Alexa routines.
Q: Can I have multiple app instances? A: Yes! Perfect for different scenarios (daily, vacation, seasonal).
Q: Can the same device be in both individual AND group monitors? A: Yes! They work independently. Great for early specific warning + later general reminder.
Q: What happens if I change my mind on naming? A: Use "Remove All Virtual Devices" button in Advanced Options, then click Done to recreate with new settings.
Q: Do the virtual contacts stay open forever? A: No - they close automatically when the device returns to normal state (door closes, lock locks, etc.)
Q: Can I monitor the same device with different delays? A: Yes - create multiple monitors for the same device with different delays.
Copy / Paste - Code.
* ========================== Alexa Device Alert Monitor 3.3.8 ==========================
* Platform: Hubitat Elevation
* Copyright 2025
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Changelog:
* 1.0.0 (2025-10-15) - Initial release
* - Uses Virtual Contact Sensors (open/closed) instead of switches for better Alexa compatibility
* - Supports Group and Individual monitors
* - Master Status Check feature - creates separate contacts per device type (Contacts, Locks, Lights)
* - Advanced option to remove all virtual devices for troubleshooting
* 2.0.0 (2025-10-15) - Fix master status check to handle missing contacts and stagger closure scheduling
* 2.0.1 (2025-10-15) - Improved logging in closeAllMasterContacts for clarity when contacts are already closed
* 2.1.0 (2025-10-16) - Added "Repeat Alert Until Resolved" option for group and individual monitors
* - Reuses delay setting for repeat interval, disabled for zero-delay monitors
* - Reopens virtual contact for 10 seconds if alert persists, stops when resolved
* 2.2.0 (2025-10-16) - Added configurable repeat limits (1-10, default 3) to prevent alert fatigue
* - Shows repeat count in monitor descriptions
* - Tracks repeat progress in debug logs
* 2.2.1 (2025-10-16) - Removed automatic deletion of all virtual devices in initialize() to preserve device IDs for Alexa compatibility
* 3.3.4 (2025-10-18) - Added separate repeat interval for instant alerts (delay=0)
* 3.3.5 (2025-10-18) - Added configurable virtual device open duration (1-10 sec, default 5)
- Made group name required with no auto-naming
- Updated logs to reflect dynamic open duration
definition(
name: "Alexa Device Alert Monitor",
namespace: "ADAM 3.3.8 - Warlock-Weary + Claude + Grok",
author: "Warlock-Weary + Claude + Grok",
description: "Monitor devices and control virtual contact sensors for Alexa announcements",
category: "Convenience",
iconUrl: "",
iconX2Url: "",
iconX3Url: ""
preferences {
page name: "pageMain"
page name: "pageGroupMonitor"
page name: "pageIndividualMonitor"
page name: "pageRemoveGroupMonitor"
page name: "pageRemoveIndividualMonitor"
Map pageMain() {
state.remove("removedMonitor")
state.remove("removeMonitor")
dynamicPage(name: "pageMain", title: "<b>Alexa Device Alert Monitor Setup</b>", uninstall: true, install: true) {
section("<hr style='background-color:#000000; height: 2px; border: 0;'><b>📦 Group Monitors:</b>") {
paragraph "Monitor multiple devices together - if ANY device is in alert state, the virtual contact sensor opens."
state.groupMonitors?.each { Integer monitorNum ->
String customName = settings."groupMonitor_${monitorNum}_name"
String type = settings."groupMonitor_${monitorNum}_type"
String autoName = type ? "Any ${getTypeDisplayName(type)} Open" : "Group Monitor ${monitorNum}"
String monitorName = customName ?: autoName
Boolean isEnabled = settings."groupMonitor_${monitorNum}_enabled" != false
String desc = getGroupMonitorDescription(monitorNum)
String statusIcon = isEnabled ? "✅" : "⏸️"
href(name: "pageGroupMonitor${monitorNum}Href",
page: "pageGroupMonitor",
params: [monitorNumber: monitorNum],
title: "${statusIcon} ${monitorName}",
description: desc ?: "Click/tap to configure...",
state: desc ? "complete" : null)
input name: "btnNewGroupMonitor", type: "button", title: "➕ Add New Group Monitor"
section("<hr style='background-color:#000000; height: 2px; border: 0;'><b>🔧 Individual Monitors:</b>") {
paragraph "Monitor single devices - one device per virtual contact sensor alert."
state.individualMonitors?.each { Integer monitorNum ->
com.hubitat.app.DeviceWrapper dev = settings."individualMonitor_${monitorNum}_device"
String monitorName = dev?.displayName ?: "Individual Monitor ${monitorNum}"
Boolean isEnabled = settings."individualMonitor_${monitorNum}_enabled" != false
String desc = getIndividualMonitorDescription(monitorNum)
href(name: "pageIndividualMonitor${monitorNum}Href",
page: "pageIndividualMonitor",
input name: "btnNewIndividualMonitor", type: "button", title: "➕ Add New Individual Monitor"
section("<hr style='background-color:#000000; height: 2px; border: 0;'><b>🔘 Master Status Check:</b>") {
paragraph "Trigger a full status check of all monitors with a button press. Creates separate virtual contacts for each device type you're monitoring."
input name: "masterStatusCheckEnabled", type: "bool", title: "Enable Master Status Check",
defaultValue: false, submitOnChange: true
if (settings["masterStatusCheckEnabled"]) {
input name: "masterStatusCheckButton", type: "capability.pushableButton",
title: "Button Device:", submitOnChange: true
if (settings["masterStatusCheckButton"]) {
input name: "masterStatusCheckButtonNumber", type: "number",
title: "Button Number:", range: "1..16", defaultValue: 1, required: true
paragraph "<b>Virtual Contact Sensors Created:</b>"
paragraph "<small>The app will automatically create contacts only for device types you're monitoring:</small>"
paragraph "• <b>V-ADAM - Master Status Check - Contacts</b> (opens if any contacts open)"
paragraph "• <b>V-ADAM - Master Status Check - Locks</b> (opens if any locks unlocked)"
paragraph "• <b>V-ADAM - Master Status Check - Lights</b> (opens if any lights on)"
paragraph "<small>When button ${settings['masterStatusCheckButtonNumber'] ?: '1'} is pushed, each contact will open briefly if that device type has alerts, then close after a few seconds.</small>"
section("<hr style='background-color:#000000; height: 2px; border: 0;'><b>⚙️ Advanced Options:</b>") {
// Virtual Device Open Duration - FIRST
paragraph "<b>🧭 Set Virtual Device Open Duration:</b>"
paragraph "Set how long the virtual device stays open (1-10 seconds, default 5)"
input name: "virtualDeviceOpenDuration", type: "number",
title: "Virtual Device Open Duration (seconds):",
range: "1..10",
defaultValue: 5,
required: false,
width: 6
// Debug Logging Options - SECOND
paragraph "<hr>"
paragraph "<b>🔍 Debug Logging:</b>"
input name: "debugLogging", type: "bool", title: "Enable debug logging", defaultValue: false, submitOnChange: true
if (settings["debugLogging"]) {
input name: "debugLoggingAutoDisable", type: "bool", title: "Automatically disable debug logging after 30 minutes",
defaultValue: true, width: 8
// Danger Zone - LAST
paragraph "<hr>"
paragraph "<b>⚠️ Danger Zone:</b>"
input name: "btnRemoveAllDevices", type: "button", title: "🗑️ Remove All Virtual Devices", submitOnChange: true
paragraph "<i>This will delete ALL virtual contact sensors created by this app. Your monitor settings will be preserved, but devices will need to be recreated by clicking Done.</i>"
Map pageGroupMonitor(Map params) {
Integer monitorNum
if (params?.monitorNumber != null) {
state.currMonitorNum = params.monitorNumber
monitorNum = params.monitorNumber
else {
monitorNum = state.currMonitorNum
dynamicPage(name: "pageGroupMonitor", title: "<b>Group Monitor Configuration</b>", uninstall: false, install: false, nextPage: "pageMain") {
section("<hr style='background-color:#000000; height: 2px; border: 0;'><b>Group Settings:</b>") {
input name: "groupMonitor_${monitorNum}_enabled", type: "bool", title: "Enable this monitor",
defaultValue: true, submitOnChange: true
input name: "groupMonitor_${monitorNum}_name", type: "text", title: "Custom Group Name (required):",
required: true, submitOnChange: true,
description: "Enter a custom name to identify this group."
input name: "groupMonitor_${monitorNum}_type", type: "enum", title: "Device Type:",
options: ["contact": "Contact Sensor", "lock": "Lock", "switch": "Switch/Light"],
if (settings."groupMonitor_${monitorNum}_type") {
String devType = settings."groupMonitor_${monitorNum}_type"
String capability = getCapabilityForType(devType)
input name: "groupMonitor_${monitorNum}_devices", type: "capability.${capability}",
title: "Select Devices:", multiple: true, required: true, submitOnChange: true
input name: "groupMonitor_${monitorNum}_delay", type: "number", title: "Initial Delay (minutes, 0=immediate):",
range: "0..60", defaultValue: 0, required: true, width: 6
input name: "groupMonitor_${monitorNum}_repeat", type: "bool", title: "Repeat Alert Until Resolved",
if (settings."groupMonitor_${monitorNum}_repeat") {
input name: "groupMonitor_${monitorNum}_maxRepeats", type: "number",
title: "Maximum number of repeats:",
range: "1..10", defaultValue: 3, required: true, width: 6
input name: "groupMonitor_${monitorNum}_repeatInterval", type: "number",
title: "Repeat Interval (minutes):",
range: "1..60", defaultValue: 5, required: true, width: 6
input name: "groupMonitor_${monitorNum}_modes", type: "mode", title: "Only alert in these modes (optional):",
multiple: true, required: false
if (settings."groupMonitor_${monitorNum}_type" && settings."groupMonitor_${monitorNum}_devices" && settings."groupMonitor_${monitorNum}_name") {
String displayName = settings."groupMonitor_${monitorNum}_name"
paragraph "<b>Virtual Contact Sensor:</b> V-ADAM - ${displayName} Alert"
section() {
href(name: "hrefRemoveGroupMonitor",
page: "pageRemoveGroupMonitor",
title: "🗑️ Remove This Group Monitor",
description: "Delete this monitor and its virtual contact sensor",
Map pageIndividualMonitor(Map params) {
Integer monitorNum
else {
dynamicPage(name: "pageIndividualMonitor", title: "<b>Individual Monitor Configuration</b>", uninstall: false, install: false, nextPage: "pageMain") {
section("<hr style='background-color:#000000; height: 2px; border: 0;'><b>Monitor Settings:</b>") {
input name: "individualMonitor_${monitorNum}_enabled", type: "bool", title: "Enable this monitor",
input name: "individualMonitor_${monitorNum}_type", type: "enum", title: "Device Type:",
if (settings."individualMonitor_${monitorNum}_type") {
String devType = settings."individualMonitor_${monitorNum}_type"
input name: "individualMonitor_${monitorNum}_device", type: "capability.${capability}",
title: "Select Device:", multiple: false, required: true, submitOnChange: true
input name: "individualMonitor_${monitorNum}_delay", type: "number", title: "Initial Delay (minutes, 0=immediate):",
input name: "individualMonitor_${monitorNum}_repeat", type: "bool", title: "Repeat Alert Until Resolved",
if (settings."individualMonitor_${monitorNum}_repeat") {
input name: "individualMonitor_${monitorNum}_maxRepeats", type: "number",
input name: "individualMonitor_${monitorNum}_repeatInterval", type: "number",
input name: "individualMonitor_${monitorNum}_modes", type: "mode", title: "Only alert in these modes (optional):",
if (settings."individualMonitor_${monitorNum}_device") {
String stateName = getStateNameForType(devType)
String switchName = "V-ADAM - ${getTypeDisplayName(devType)} ${stateName} - ${dev.displayName} Alert"
paragraph "<b>Virtual Contact Sensor Name:</b> ${switchName}"
section() {
href(name: "hrefRemoveIndividualMonitor",
page: "pageRemoveIndividualMonitor",
title: "🗑️ Remove This Individual Monitor",
Map pageRemoveGroupMonitor(Map params) {
dynamicPage(name: "pageRemoveGroupMonitor", title: "Remove Group Monitor", uninstall: false, install: false, nextPage: "pageMain") {
if (params?.monitorNumber != null) state.removeMonitor = params.monitorNumber
section("") {
if (state.removeMonitor != null && state.removedMonitor != true) {
String customName = settings."groupMonitor_${state.removeMonitor}_name"
String type = settings."groupMonitor_${state.removeMonitor}_type"
String autoName = type ? "Any ${getTypeDisplayName(type)} Open" : "Group Monitor"
String switchName = customName ?: autoName
paragraph "⚠️ This will delete the virtual contact sensor 'V-ADAM - ${switchName} Alert' and all settings for this monitor."
paragraph "Any Alexa routines using this sensor will stop working."
paragraph "Press the button below to confirm removal, or press 'Next' to cancel."
input name: "btnRemoveGroupMonitor.${state.removeMonitor}", type: "button", title: "🗑️ Confirm Removal", submitOnChange: true
else {
if (state.removedMonitor) paragraph "✅ Monitor removed. Press 'Next' to continue."
else paragraph "Unknown removal status. Try again if needed. Press 'Next' to continue."
Map pageRemoveIndividualMonitor(Map params) {
dynamicPage(name: "pageRemoveIndividualMonitor", title: "Remove Individual Monitor", uninstall: false, install: false, nextPage: "pageMain") {
section("") {
com.hubitat.app.DeviceWrapper dev = settings."individualMonitor_${state.removeMonitor}_device"
String devType = settings."individualMonitor_${state.removeMonitor}_type"
String stateName = devType ? getStateNameForType(devType) : "Alert"
String typeDisplay = devType ? getTypeDisplayName(devType) : "Device"
String switchName = dev ? "V-ADAM - ${typeDisplay} ${stateName} - ${dev.displayName} Alert" : "Monitor ${state.removeMonitor}"
paragraph "⚠️ This will delete the virtual contact sensor '${switchName}' and all settings for this monitor."
input name: "btnRemoveIndividualMonitor.${state.removeMonitor}", type: "button", title: "🗑️ Confirm Removal", submitOnChange: true
else {
String getGroupMonitorDescription(Integer monitorNum) {
String desc = ""
List devices = settings."groupMonitor_${monitorNum}_devices"
Integer delay = settings."groupMonitor_${monitorNum}_delay"
Boolean repeatEnabled = settings."groupMonitor_${monitorNum}_repeat" == true
if (devices && type) {
desc = "${devices.size()} ${getTypeDisplayName(type)}(s)"
if (delay != null) {
desc += delay == 0 ? " • Immediate" : " • ${delay} min delay"
if (repeatEnabled) {
Integer repeatInterval = settings."groupMonitor_${monitorNum}_repeatInterval" ?: 5
Integer maxRepeats = settings."groupMonitor_${monitorNum}_maxRepeats" ?: 3
desc += " • Repeat every ${repeatInterval} min (${maxRepeats}x)"
if (!isEnabled) {
desc += " • DISABLED"
return desc
String getIndividualMonitorDescription(Integer monitorNum) {
String desc = ""
com.hubitat.app.DeviceWrapper device = settings."individualMonitor_${monitorNum}_device"
String type = settings."individualMonitor_${monitorNum}_type"
Integer delay = settings."individualMonitor_${monitorNum}_delay"
Boolean repeatEnabled = settings."individualMonitor_${monitorNum}_repeat" == true
if (device && type) {
desc = getTypeDisplayName(type)
Integer repeatInterval = settings."individualMonitor_${monitorNum}_repeatInterval" ?: 5
Integer maxRepeats = settings."individualMonitor_${monitorNum}_maxRepeats" ?: 3
if (!isEnabled) {
return desc
String getCapabilityForType(String type) {
switch(type) {
case "contact": return "contactSensor"
case "lock": return "lock"
case "switch": return "switch"
default: return "sensor"
String getTypeDisplayName(String type) {
switch(type) {
case "contact": return "Garage Door"
case "lock": return "Lock"
case "switch": return "Light"
default: return "Device"
String getStateNameForType(String type) {
switch(type) {
case "contact": return "Open"
case "lock": return "Open"
case "switch": return "On"
default: return "Alert"
String getAttributeForType(String type) {
switch(type) {
case "contact": return "contact"
default: return "state"
String getAlertValueForType(String type) {
switch(type) {
case "contact": return "open"
case "lock": return "unlocked"
case "switch": return "on"
default: return "active"
void removeGroupMonitor(Integer monitorNum) {
logDebug "removeGroupMonitor($monitorNum)"
// Delete virtual contact sensor
if (type) {
String autoName = "Any ${getTypeDisplayName(type)} Open"
deleteVirtualSwitch("V-ADAM - ${switchName} Alert")
// Remove all settings for this monitor
def settingNamesToRemove = settings?.keySet()?.findAll { it.startsWith("groupMonitor_${monitorNum}_") }
logDebug " Settings to remove: $settingNamesToRemove"
settingNamesToRemove.each { settingName ->
app.removeSetting(settingName)
state.groupMonitors.remove(monitorNum as Integer)
state.remove('removeMonitor')
state.removedMonitor = true
logDebug "Finished removing group monitor $monitorNum"
void removeIndividualMonitor(Integer monitorNum) {
logDebug "removeIndividualMonitor($monitorNum)"
if (dev && devType) {
deleteVirtualSwitch(switchName)
def settingNamesToRemove = settings?.keySet()?.findAll { it.startsWith("individualMonitor_${monitorNum}_") }
state.individualMonitors.remove(monitorNum as Integer)
logDebug "Finished removing individual monitor $monitorNum"
void appButtonHandler(btn) {
switch (btn) {
case "btnNewGroupMonitor":
if (state.groupMonitors == null) state.groupMonitors = []
Integer newNum = (state.groupMonitors?.size() > 0) ? ((state.groupMonitors[-1] as Integer) + 1) : 0
state.groupMonitors << newNum
break
case "btnNewIndividualMonitor":
if (state.individualMonitors == null) state.individualMonitors = []
Integer newNum = (state.individualMonitors?.size() > 0) ? ((state.individualMonitors[-1] as Integer) + 1) : 0
state.individualMonitors << newNum
break
case { it.startsWith("btnRemoveGroupMonitor.") }:
Integer monitorNum = (btn - "btnRemoveGroupMonitor.") as Integer
removeGroupMonitor(monitorNum)
break
case { it.startsWith("btnRemoveIndividualMonitor.") }:
Integer monitorNum = (btn - "btnRemoveIndividualMonitor.") as Integer
removeIndividualMonitor(monitorNum)
break
case "btnRemoveAllDevices":
removeAllVirtualDevices()
break
default:
log.debug "Unhandled button press: $btn"
com.hubitat.app.DeviceWrapper createVirtualSwitch(String switchName) {
logDebug "Creating virtual contact sensor: ${switchName}"
try {
com.hubitat.app.DeviceWrapper existingDevice = getChildDevice("AlexaAlert_${app.id}_${switchName}")
if (existingDevice) {
logDebug "Virtual contact sensor already exists: ${switchName}"
return existingDevice
com.hubitat.app.DeviceWrapper device = addChildDevice(
"hubitat",
"Virtual Contact Sensor",
"AlexaAlert_${app.id}_${switchName}",
label: switchName
logDebug "Created virtual contact sensor: ${switchName}"
return device
catch (Exception e) {
log.error "Error creating virtual contact sensor ${switchName}: ${e.message}"
return null
void deleteVirtualSwitch(String switchName) {
logDebug "Deleting virtual contact sensor: ${switchName}"
try {
com.hubitat.app.DeviceWrapper device = getChildDevice("AlexaAlert_${app.id}_${switchName}")
if (device) {
deleteChildDevice("AlexaAlert_${app.id}_${switchName}")
logDebug "Deleted virtual contact sensor: ${switchName}"
log.error "Error deleting virtual contact sensor ${switchName}: ${e.message}"
void removeAllVirtualDevices() {
log.warn "Removing ALL virtual devices created by this app..."
Integer deletedCount = 0
try {
List<com.hubitat.app.DeviceWrapper> childDevices = getChildDevices()
childDevices.each { device ->
try {
String deviceName = device.label ?: device.name
deleteChildDevice(device.deviceNetworkId)
log.info "Deleted: ${deviceName}"
deletedCount++
log.error "Error deleting device ${device.deviceNetworkId}: ${e.message}"
log.warn "Removed ${deletedCount} virtual device(s). Click Done to recreate them based on current monitor settings."
log.error "Error removing devices: ${e.message}"
void deviceEventHandler(evt) {
logDebug "Device event: ${evt.device.displayName} ${evt.name} = ${evt.value}"
// Check all group monitors
if (devices?.find { it.id == evt.device.id }) {
handleGroupMonitorEvent(monitorNum)
// Check all individual monitors
if (device?.id == evt.device.id) {
handleIndividualMonitorEvent(monitorNum)
void buttonEventHandler(evt) {
logDebug "Button event: ${evt.device.displayName} button ${evt.value} pushed"
Integer buttonNum = settings["masterStatusCheckButtonNumber"] ?: 1
Integer pushedButton = evt.value as Integer
if (pushedButton == buttonNum) {
logDebug "Master status check triggered by button ${buttonNum}"
performMasterStatusCheck()
void performMasterStatusCheck() {
logDebug "Performing master status check..."
Map<String, Boolean> typeAlerts = [contact: false, lock: false, switch: false]
Set<String> monitoredTypes = []
if (settings."groupMonitor_${monitorNum}_enabled" != false) {
if (type) monitoredTypes.add(type)
String attribute = getAttributeForType(type)
String alertValue = getAlertValueForType(type)
if (devices.any { it.currentValue(attribute) == alertValue }) {
typeAlerts[type] = true
if (settings."individualMonitor_${monitorNum}_enabled" != false) {
if (device.currentValue(attribute) == alertValue) {
logDebug "Master status check results - Contacts: ${typeAlerts.contact}, Locks: ${typeAlerts.lock}, Lights: ${typeAlerts.switch}"
// Open contacts immediately (all types that are monitored)
if (monitoredTypes.contains("contact")) {
handleMasterContactByType("Contacts", typeAlerts.contact)
if (monitoredTypes.contains("lock")) {
handleMasterContactByType("Locks", typeAlerts.lock)
if (monitoredTypes.contains("switch")) {
handleMasterContactByType("Lights", typeAlerts.switch)
// Schedule a single closure for all contacts
runIn(10, "closeAllMasterContacts", [data: [monitoredTypes: monitoredTypes]])
void handleMasterContactByType(String typeName, Boolean hasAlert) {
String contactName = "V-ADAM - Master Status Check - ${typeName}"
com.hubitat.app.DeviceWrapper contact = getChildDevice("AlexaAlert_${app.id}_${contactName}")
if (!contact) {
logDebug "Master contact for ${typeName} not found (may not be monitoring this type)"
return
if (hasAlert) {
if (contact.currentValue("contact") != "open") {
contact.open()
logDebug "Opened master contact: ${contactName}"
} else {
if (contact.currentValue("contact") == "open") {
contact.close()
logDebug "Closed master contact: ${contactName} (no alerts)"
void closeAllMasterContacts(Map data) {
Set<String> monitoredTypes = data.monitoredTypes
logDebug "Closing all master contacts"
monitoredTypes.each { type ->
String typeName = type == "contact" ? "Contacts" : (type == "lock" ? "Locks" : "Lights")
if (!contact) {
logDebug "Failed to close master contact: ${contactName} (device not found)"
return
logDebug "Master contact: ${contactName} is already closed"
return
contact.close()
logDebug "Closed master contact: ${contactName}"
void verifyClosure(Map data) {
String contactName = data.contactName
if (contact) {
logDebug "Verification: ${contactName} state is ${contact.currentValue('contact')}"
} else {
logDebug "Verification failed: ${contactName} not found"
void cleanupOpenContacts() {
logDebug "Running cleanup for open master contacts"
["Contacts", "Locks", "Lights"].each { typeName ->
if (contact && contact.currentValue("contact") == "open") {
contact.close()
logDebug "Cleanup: Closed master contact: ${contactName}"
void handleGroupMonitorEvent(Integer monitorNum) {
// Check if monitor is enabled
if (!isEnabled) {
logDebug "Group monitor ${monitorNum} is disabled, skipping"
return
Integer delay = settings."groupMonitor_${monitorNum}_delay" ?: 0
List modes = settings."groupMonitor_${monitorNum}_modes"
if (!devices || !type) return
// Auto-generate name if not provided
String autoName = devices.collect { it.displayName }.join(", ")
String fullSwitchName = "V-ADAM - ${switchName} Alert"
// Check if we're in allowed mode
if (modes && !modes.contains(location.mode)) {
logDebug "Group monitor ${monitorNum}: Not in allowed mode, skipping"
return
// Check if ANY device is in alert state
Boolean anyInAlertState = devices.any { device ->
com.hubitat.app.DeviceWrapper virtualSwitch = getChildDevice("AlexaAlert_${app.id}_${fullSwitchName}")
if (anyInAlertState) {
logDebug "Group monitor ${monitorNum}: Device(s) in alert state"
if (delay > 0) {
logDebug "Scheduling switch ON in ${delay} minutes"
runIn(delay * 60, "turnOnGroupSwitch", [data: [monitorNum: monitorNum]])
} else {
turnOnGroupSwitch([monitorNum: monitorNum])
// Schedule repeat if enabled
logDebug "Scheduling repeat alert for group monitor ${monitorNum} every ${repeatInterval} minutes (max ${maxRepeats}x)"
runIn((repeatInterval * 60) + 10, "repeatGroupAlert", [data: [monitorNum: monitorNum, repeatCount: 0]])
} else {
logDebug "Group monitor ${monitorNum}: All devices OK"
// Note: We don't unschedule() here because it would cancel scheduled events for ALL monitors.
// The scheduled methods (turnOnGroupSwitch, repeatGroupAlert) already check state before acting.
if (virtualSwitch?.currentValue("contact") == "open") {
virtualSwitch.close()
logDebug "Closed contact: ${fullSwitchName}"
void turnOnGroupSwitch(Map data) {
Integer monitorNum = data.monitorNum
// Double-check devices are still in alert state
if (virtualSwitch && virtualSwitch.currentValue("contact") != "open") {
virtualSwitch.open()
logDebug "Opened contact: ${fullSwitchName}"
Integer duration = settings.virtualDeviceOpenDuration ?: 5
runIn(duration, "closeGroupSwitch", [data: [monitorNum: monitorNum]])
void turnOnIndividualSwitch(Map data) {
if (!device || !type) return
String stateName = getStateNameForType(type)
String switchName = "V-ADAM - ${getTypeDisplayName(type)} ${stateName} - ${device.displayName} Alert"
// Double-check device is still in alert state
com.hubitat.app.DeviceWrapper virtualSwitch = getChildDevice("AlexaAlert_${app.id}_${switchName}")
logDebug "Opened contact: ${switchName}"
runIn(duration, "closeIndividualSwitch", [data: [monitorNum: monitorNum]])
void repeatGroupAlert(Map data) {
Integer repeatCount = data.repeatCount ?: 0
// Ensure maxRepeats is within valid range
if (maxRepeats < 1) maxRepeats = 1
if (maxRepeats > 10) maxRepeats = 10
// Check if we've hit the limit
if (repeatCount >= maxRepeats) {
logDebug "Group monitor ${monitorNum}: Completed ${maxRepeats} repeats, stopping"
return
if (!isEnabled || !repeatEnabled || !devices || !type) {
logDebug "Repeat stopped for group monitor ${monitorNum}: disabled or invalid settings"
return
logDebug "Group monitor ${monitorNum}: Not in allowed mode, skipping repeat"
return
logDebug "Repeat ${repeatCount + 1}/${maxRepeats} for group monitor ${monitorNum}"
runIn((repeatInterval * 60) + duration, "repeatGroupAlert", [data: [monitorNum: monitorNum, repeatCount: repeatCount + 1]])
} else {
logDebug "Group monitor ${monitorNum}: Alert resolved after ${repeatCount} repeat(s)"
void handleIndividualMonitorEvent(Integer monitorNum) {
if (!isEnabled) {
logDebug "Individual monitor ${monitorNum} is disabled, skipping"
return
Integer delay = settings."individualMonitor_${monitorNum}_delay" ?: 0
List modes = settings."individualMonitor_${monitorNum}_modes"
logDebug "Individual monitor ${monitorNum}: Not in allowed mode, skipping"
return
logDebug "Individual monitor ${monitorNum}: Device in alert state"
if (delay > 0) {
runIn(delay * 60, "turnOnIndividualSwitch", [data: [monitorNum: monitorNum]])
} else {
turnOnIndividualSwitch([monitorNum: monitorNum])
logDebug "Scheduling repeat alert for individual monitor ${monitorNum} every ${repeatInterval} minutes (max ${maxRepeats}x)"
runIn((repeatInterval * 60) + 10, "repeatIndividualAlert", [data: [monitorNum: monitorNum, repeatCount: 0]])
} else {
logDebug "Individual monitor ${monitorNum}: Device OK"
// The scheduled methods (turnOnIndividualSwitch, repeatIndividualAlert) already check state before acting.
logDebug "Closed contact: ${switchName}"
void closeGroupSwitch(Map data) {
if (virtualSwitch && virtualSwitch.currentValue("contact") == "open") {
logDebug "Closed contact: ${fullSwitchName} after ${duration} seconds"
void closeIndividualSwitch(Map data) {
logDebug "Closed contact: ${switchName} after ${duration} seconds"
void repeatIndividualAlert(Map data) {
logDebug "Individual monitor ${monitorNum}: Completed ${maxRepeats} repeats, stopping"
return
if (!isEnabled || !repeatEnabled || !device || !type) {
logDebug "Repeat stopped for individual monitor ${monitorNum}: disabled or invalid settings"
return
logDebug "Individual monitor ${monitorNum}: Not in allowed mode, skipping repeat"
return
logDebug "Repeat ${repeatCount + 1}/${maxRepeats} for individual monitor ${monitorNum}"
runIn((repeatInterval * 60) + duration, "repeatIndividualAlert", [data: [monitorNum: monitorNum, repeatCount: repeatCount + 1]])
} else {
logDebug "Individual monitor ${monitorNum}: Alert resolved after ${repeatCount} repeat(s)"
void installed() {
log.info "Installed"
initialize()
void updated() {
log.info "Updated"
unsubscribe()
unschedule()
initialize()
// Persist default virtual device open duration if not set
if (settings.virtualDeviceOpenDuration == null) {
app.updateSetting("virtualDeviceOpenDuration", [type: "number", value: 5])
log.debug "Persisted default virtual device open duration: 5 seconds"
void initialize() {
log.info "Initializing Alexa Device Alert Monitor"
if (settings["debugLoggingAutoDisable"] != false) {
log.debug "Debug logging enabled for 30 minutes"
runIn(1800, disableDebugLogging)
} else {
log.debug "Debug logging enabled (will not auto-disable)"
// Create master status check contact sensors if enabled
if (isEnabled) {
if (isEnabled) {
// Create virtual contacts for each monitored type
String contactName = "V-ADAM - Master Status Check - Contacts"
createVirtualSwitch(contactName)
logDebug "Created/verified master contact for Contacts"
String contactName = "V-ADAM - Master Status Check - Locks"
logDebug "Created/verified master contact for Locks"
String contactName = "V-ADAM - Master Status Check - Lights"
logDebug "Created/verified master contact for Lights"
// Subscribe to button events
subscribe(settings["masterStatusCheckButton"], "pushed", buttonEventHandler)
logDebug "Subscribed to button: ${settings['masterStatusCheckButton'].displayName}"
// Create/update virtual contact sensors for group monitors
if (!isEnabled) {
logDebug "Skipping disabled group monitor ${monitorNum}"
return
com.hubitat.app.DeviceWrapper virtualSwitch = createVirtualSwitch(fullSwitchName)
devices.each { device ->
subscribe(device, attribute, deviceEventHandler)
// Create/update virtual contact sensors for individual monitors
if (!isEnabled) {
logDebug "Skipping disabled individual monitor ${monitorNum}"
return
com.hubitat.app.DeviceWrapper virtualSwitch = createVirtualSwitch(switchName)
log.info "Initialization complete"
void disableDebugLogging() {
log.info "Debug logging automatically disabled after 30 minutes"
app.updateSetting("debugLogging", [type: "bool", value: false])
void logDebug(String msg) {
log.debug msg
