Nice. I was working on something like this a while back but the requirement for a mac and applescript for the API killed it for me. I couldn't find any way to do it easily on windows.
I ended up doing something similar with tuneaero and tunerelay on windows. That has a direct api you can poll on tunerelay. No need for a 3rd party api or anything.
@gavincampbell the whole Mac requirement is a bummer but if you have this eco system it’s great, I’ll have to check out the tune relay thing, sounds interesting. Eventually I want to leverage vlcthing and source switching for announcements etc.
It seems like you replaced the code? You should use the code without alteration then create a new device and assign this driver to it. In the new device you can specify the ip and port
So I created the device using the ip of the machine running airfoil and the port 8080.
This is what I see.
Not sure the airfoil API is installed properly.
This is what I see in terminal when I dbl click "install" in the SCRIPTS folder.
Last login: Fri Dec 11 14:57:43 on ttys000
