C7 on 2.4.0.151 Major bug: Eaton direct association cannot be disassociated because there is no "no association" choice in the drop down list to select. In another word, once you select an association for dimmer/accessory pair there is no way to undo it on 2.4. Such choice was there on 2.3 versions. pls reenable it for 2.4
Also, if eaton dimmer 9640 with firmware version 2 or eaton dimmer 9643 is used, they will be recognized as eaton dimmer and they can be paired with accessory 9642. BUT, once association pair is made, changing dimmer level will turn off both unit. not sure if this is a bug or just not supported. the way to get around this is to use 9640 with firmware version 1 for direct association.
