I have a Mimo2+ and I'm trying to control the relays in it using Rule Machine 5.1 but, low and behold, I can't seem to find Relays anywhere in Rule Machine. I'm hoping it's me. Am I missing it somewhere?
TIA!
TIA!
A relay is just a โswitchโ device. Try using a switch device in the rule.
Been there, done that. For some reason the Mimo2+ only seems to respond to the relay (that I can see, correct me if I'm wrong). Thanks for the suggestion. ![]()
What driver are you using?
Call me crazy. I went back and tried the switch and it worked just fine. I swear it didn't work before but maybe another issue with the rule was confusing me and causing things not to work.. Thanks for the help.
