Regularly appearing Debug message on Ring Range Extender 2
I added a Ring Range Extender 2nd Generation, and it works fine, but I notice that I get a regular Debug event from the device: "parse:zw device: 29, command: 8003, payload: 64 B0 00 , isMulticast: false". Is there a different driver I should be using here, a setting that the standard driver doesn't support, or something else?
This is normal if debug is turned on in the device settings.
Thanks! With the new repeater and two others previously installed, I have gotten reliable connections through my home, which is about 4200 sqft, and the basement area as well.
