Registration does not take me to the elevation website
Registration does not take me to the elevation website when I click register it errors with failure to connect....I can ping and go to (address):8081 but the app goes nowhere
I have rebooted ?
In the webpage with the 8081 address, it gives you an option to downgrade the hub?
Hubitat Elevation Update Tool
You are currently running hub-2.0.4.118
Select one of the following versions to switch to:
My only option is to hit submit and it tries to communicate and fails
there are no selection of loads
And using the ip without the 8081, like 192.168.1.60
What you see?
Yes when I go to the updater tool I'm using :8081 otherwise it doesn't respond
The tool is not communicating it is trying to reply only using the IP and no port number
http://192.168.1.60:8081/setup
Try this, use your hub ip
