can someone help be understand why since after updating to 2.5.0.159, when i go to my.hubitat.com and choose the registered hub link; that the connect to button is greyed out? however if i go to the discover hub option i can connect to it that way.
Your hub must have lost its connection to Hubitat's cloud. That could be because you turned this option off in Settings (you'd know), have misconfigured network settings on the hub (if you aren't fully using DHCP) or on your home network, or just encountered an odd bug with the hub.
While you can use Hubitat's network tools to figure some of this out, if you don't think you have (or want to) any custom network settings on the hub, a network reset (described in the linked section on that page) is easy and will rule out that as a problem. If you don't have physical access to the hub at the moment and want something simpler to try first, you can also try Settings > Reboot.
You're also a major release version behind, so I'd normally suggest updating. But perhaps the Internet connectivity problem is causing the hub not to see that either, so hopefully this helps. ![]()
habitat cloud is not off. using dchp for wired connection. i can use the network test in settings and ping cloud.hubitat.com just fine. have any other ideas? as of right now i am going to try updating to 2.5.1.183 from 2.5.0.159. i just hate updating from a release that has been stable for me.
well updating to 2.5.1.183, did not change it. anyone from support available to see what could be wrong?
