Refrigeration Monitor
I wrote code to check for a constant power draw. For things like refrigerators and freezers. I took the better laundry monitor code and changed it to this. this checks periodically to see if the device is drawing power over a threshold if it fails to do so it notifies the user.
here is where to get the code:
just install the 2 files as apps and its good to go.
