HI everyone,
I've been with ST for around 5yrs, and I'm now about 3/4 done migrating to HE.
I have a few ST WebCore Pistons that I want to move to HE, so I can finish moving everything on over.
I have tried setting up WebCore in HE but I keep having issues. After adding the 185 devices in WC and try to create a piston, none of my device are listed to pick from.
So I'm trying to create them in RM.
I was never that great working with WC, now I total lost with RM... lol
What I'm trying to recreate is a WC Piston that always worked great for me.
(I'm using a GE Motion/light switch, and a Door Contact Sensor)
*Once Motion is Active - Turn Bathroom Light "ON"
*Once Motion is Inactive - Turn Bathroom Light "OFF"
*But "IF" Motion is Inactive -and- Door Contact Sensor is "Closed", then Leave Light "ON"
*When Door Contact Sensor "Changes" to "Open" - Wait 1 minute and Turn Light "OFF".
I have been looking to see if someone has a similar RM setup like what I'm needing, but haven't seen one posted yet.
If someone has the same thing or similar in RM, I would be grateful if you would share it with me. Or if someone could help me recreate what I'm needing in RM, I would be very grateful.
Thank you,
(*)Here is the WC Piston that I am trying to recreate in RM.......
First, you are going to have to create this in several rules. I don't think one is going to cut it.
The first would be a trigger.
Trigger event: Motion Active
Action: Lights on
The second would be a triggered rule:
Trigger: Motion Inactive OR contact open
Condition/Rule: Contact Open
Action: Lights Off
Now this means that the lights will turn off immediately after motion is inactive. I don't know what timeout you have for the motion sensor but I would be cautious of that.
I've started doing these sorts of rules using a stand-alone action that does the actual device control and then trigger/conditional rules to run them. See Outside Automatic lights on doors/locks/presence for an example.
One idea would be:
- Action that:
- Turns on light
- Stop This Rule (cancels any previously scheduled turn-off)
- Turns off light after delay of 1 minute
- Trigger Rule when motion goes active
- Run Action 1
- Pause Action 1
- Conditional rule when motion is inactive AND door contact is Open
- Unpause Action 1
- Run Action 1
I've had a lot of luck creating virtual sensors/lights and building the rule with those to make testing easier.
@nkyspike, these simple rules work well with me :
Trigger Lights On ( Motion ) :
Rule Lights Off - Door Open ( wait 1 minutes ) :
@nkyspike beat me to it. But I have a slightly different take on it. I just tried this as a test:
A trigger to turn the light on:
A rule to turn the light off:
For my "off" I defined a rule so that if the light is on and the door is closed, the light will stay on. But if the door opens, the light will turn off after 1 minute. This means that there will also be a delay of 1 minute if there's no motion and the door is open, which might not be what you want. Works, though.
I think you can do this with a simple trigger:
Trigger Event: Motion active
Actions:
Turn on light
Wait until contact opens
Turn off light
This works for me. My motion sensor has a 30 second timer on it so that's why the delay is only set to 30 (total of 1 minute).
Thanks "Everyone" for your helpful responses to my question!
I feel a little more comfortable now, moving forward with all of your suggestions.
Once I get it working ( ) I'll post an update.
Thanks again!
@ Ryan780 Opps sorry, I forgot to mention I have the default timer set for 5 Minutes within the GE motion/light switch setting.
Thank you all again, for all your help and ideas.
I went ahead and setup two different rooms using TranDzung RM layout, and everything is working out great so far!
Here is how it looks for me........
"THANKS"
Couldn't this be done in one rule?
Conditions: motion active
Rule: motion active
Actions for true: ON light
Actions for false:
Simple conditional action If contact is open
Off light with delay of 1 Mon cancel on truth change.
Hi @homeauto2112
Just looking at your rule and I see in the select conditions you have an 'AND'.
How did you put that in there?
I've had a rummage around and cannot see how to do it.
That's because it isn't a AND it's a "and" in the name of the device
@bobbles It's in the drop-down tab, in Define the Rule.
Ah ha. I kept looking at it thinking 'how did he do that'.
Strange device name though, Motion sensor and light switch.
Thanks for the reply but I appreciate it can be done in rule definition but I was talking about conditions not rule definition.
I'm using the GE Light Switch, Vacancy/Occupancy Sensor.
It's a light switch with a built in motion sensor, works really well.
Ah ha. The coin it has fallen.
@nkyspike I've been looking at that switch. Is the motion sensor visible to HE? Can I use rules to control the light? Or is it all self contained?
@jabecker I'm still a newbie with HE, so I'll post some screen shots in hoping to answer some of your questions. But it does look to have full adjustments for both Motion & Lighting to work with.
Sorry I couldn't be more helpful.
