Recommended change to settings - localization
I'd like to suggest a change or call it a feature request -
The page in settings called Location has a definition of :
"Set the location and timezone of your hub"
I suggest this should read :
"Set the localization settings of your hub"
Since the values of Long/Lat, Postal Code, Temp Scale, Time Format and Sunrise / Sunset exist on this screen, it is more inclusive a description.
In addition, the hub Time should also be displayed here - although it can be debated since it already exists under Hub Details - IMHO it should also be moved to this settings screen instead.
Finally - The Settings Location panel page should Drop the tab to 'Modes' as this is not consistent with the other Settings page layouts and is legacy and unnecessary. Modes already exists separately on the Settings main page.
I also submit the title of the page 'Location' is not as reflective as 'Localization' would be for a title to this settings screen.
Thanks. These are good suggestions.
