Recommendation Request: shock or glass break sensor
I am requesting a recommendation for a “shock”or glass break sensor to let me know if a window has been broken. Sensor should be Zigbee.
(Please note: the aqara vibration sensor does not have the “shock” attribute.)
Any suggestions?
Ring has Glass Break sensors, but they are Z-wave, so won’t meet your criteria. Those are the only ones I know…
Just got 5 of these from AliExpress, so far so good. Occasionally they go haywire(both w/ HE & SmartLife) but mine regained its sanity. When they go haywire they report repeated activation every 3 seconds. Using @kkossev Tuya Vibration Sensor Driver.
These are like 5 bucks each, use AAA batteries(not incl.). If you order 5 or > they are 4.88USD each
Device Data:
Application 41
Endpoint Id 01
Manufacturer _TZ3000_lzdjjfss
Model TS0210
Tuya Version 1.0.1
There is a thread containg lots of info about this model, I think it’s the thread about this driver.
https://www.aliexpress.us/item/3256807088481206.html?spm=a2g0o.order_detail.order_detail_item.4.10b2126aYwwpGD&gatewayAdapt=glo2usa
Do your devices have a “shock” attribute?
Yes, I use them in HSM for glass break/sliding door prying open detection. Krassimir did his magic and they report shock & vibration. In SmartLife it has both drop & vibration detection
Capabilities
AccelerationSensor
Battery
Configuration
HealthCheck
Refresh
Sensor
ShockSensor
ThreeAxis- I didn’t see any 3Axis reports
