This usually means that you had a cloud integration set up in the past, like Life360 or HubConnect to SmartThings.
If HubConnect on SmartThings, be sure to remove that app from your SmartThings account.
App '471' was the number of the app on Hubitat that used to be installed, and would have received these cloud connections previously. You must have removed app 471 from your hub.
Hmm.. makes sense.. kind of. Couple of days ago I installed hubconnect, it works and I'm using it with ST. Today I factory reset my kids phone and reinstalled it.
Hubconnect and life360 works normally. I have not removed anything..
I'm getting "error 500" when testing url: http://hubipaddress/installedapp/configure/471
Those pings are coming from amazon aws ..well it's a cloud service.. and there's nothing much to get out of it.
Now I'm getting this error in log:
"Received cloud request for App 79 that does not exist, path: /menu/presence/239"
Any idea what is App79? I haven't installed or deleted new apps. I have only updated hubitat when update has been available. This seems to be something that started couple of weeks ago.
Do you use Life360, or another cloud-based Presence tool? It sort of sounds like an App was removed from Hubitat, but the corresponding cloud service is still trying to update the Presence of a device via a Hubitat App.
Hi, yeah I'm using life360 as a presence tool. I have also enabled Hubitat app location but everything has been same for the last 12 months. It sounds same as described in other topic but I'm not keen to remove application and install it again.. everything works but this is more like ...I'm annoyed that I have those lines in my log
I am getting this error:
Received cloud request for App 79 that does not exist, path: /device/1717 from 44.220.147.140
[sys:1](http://internal IP /logs#)2024-11-06 09:52:47.540 PM[warn](http://internal IP logs#)Received cloud request for App 79 that does not exist, path: /device/1717 from 44.202.191.250
I followed the suggestion above to remove Hubitat and reinstall it. I did that, still getting the error. What I have observed is that this has something to do with Alexa. For the past couple of days, you cannot get Alexa any voice commands to turn lights on/off etc. Within the app, the devices all show "unresponsive"....I can still control them via hubitat but nothing is working from Alexa. I recently upgraded Hubitat and noticed the Amazon Echo skill was missing, I re-added it, still no joy. Anybody have any ideas of things I could check for?
As @ogiewon explained to the OP, this warning (itβs a warning, not an error) occurs when something outside Hubitat is still trying to reach your hub after a corresponding app was deleted from the hub.
In your case, if itβs related to Alexa, then I would suggest deleting the Hubitat Amazon Echo app from your hub, and removing the Hubitat Alexa skill from the Alexa mobile app on your phone.
If that stops the warning from recurring, then you could reinstall the Hubitat Alexa skill from the Alexa mobile app.
thanks. I removed both, then reinstalled on Alexa mobile app, the error flooded my logs. Then I installed the Echo app on Hubitat....the error is gone and i can control my devices from Alexa again!
