Recalibrate zse11?
Does anybody know if there's a way to recalibrate the zse11 or offset the temp settings on it? Its about 8 degrees off from actual temp
Total noob here but I'm learning. I was able to copy and paste the driver code where do I need to make the adjustments?
I would assume in the device settings page. You would need to go to the devices menu, select the device, and change the driver for that device in the drop down. Then save the device. Then click configure to update the driver settings. At that point, it should be one of the preferences on the page.
I don't have that particular one. In mine, the offset is done by entering a correct temperature for the device right now. (For instance, if the device reads 74F, and it is really 72F, I just enter 72 in the reference setting on the preferences page). Not sure how they do it on that driver.
That was it thank you!
