Really slow hub after most recent update
Hey gang.
I just jumped onto my hub to add another three hue lights, and it prompted me to update. I did so, but the hub itself is SERIOUSLY slow to run now I've run it.
There are only three things on the hub in the first place - two Hue Bridges, and the old-skool Alexa integration app. I only use hubitat to expose both Hue bridges - although there are probably 100 lights between the two.
Looking at the logs... here's all the output since the reboot (at the bottom).
Any suggestions on how to proceed?
Best regards,
Jules
app:62018-12-09 01:33:26.901 pm debugInitializing
dev:1932018-12-09 01:32:23.343 pm infoHue outdoor spot 1 color mode is CT
dev:1932018-12-09 01:32:23.342 pm infoHue outdoor spot 1 color temperature was set to 2732°K
dev:1932018-12-09 01:32:23.340 pm infoHue outdoor spot 1 saturation was set to 55%
dev:1932018-12-09 01:32:23.339 pm infoHue outdoor spot 1 hue was set to 13%
dev:1932018-12-09 01:32:23.337 pm infoHue outdoor spot 1 level was set to 100%
dev:1932018-12-09 01:32:23.335 pm infoHue outdoor spot 1 was turned on
app:62018-12-09 01:32:17.286 pm debugInitializing
app:12018-12-09 01:31:11.183 pm errorjava.lang.IllegalArgumentException: A device with the same device network ID exists, Please use a different DNI (updated)
app:62018-12-09 01:31:10.465 pm debugInitializing
app:12018-12-09 01:31:10.391 pm debugInitializing
app:12018-12-09 01:31:03.792 pm debugInitializing
app:62018-12-09 01:30:04.569 pm debugInitializing
app:12018-12-09 01:30:04.271 pm debugInitializing
app:62018-12-09 01:29:28.633 pm debugInitializing
dev:1072018-12-09 01:29:23.915 pm infoBedroom lamp 2 color mode is CT
dev:1072018-12-09 01:29:23.896 pm infoBedroom lamp 2 saturation was set to 80%
dev:1072018-12-09 01:29:23.886 pm infoBedroom lamp 2 hue was set to 12%
dev:1062018-12-09 01:29:09.647 pm infoBedroom lamp 1 color mode is CT
dev:1062018-12-09 01:29:09.645 pm infoBedroom lamp 1 saturation was set to 80%
dev:1062018-12-09 01:29:09.644 pm infoBedroom lamp 1 hue was set to 12%
dev:1092018-12-09 01:29:04.713 pm infoDining room uplighter color mode is CT
dev:1092018-12-09 01:29:04.705 pm infoDining room uplighter saturation was set to 56%
dev:1092018-12-09 01:29:04.702 pm infoDining room uplighter hue was set to 23%
dev:1082018-12-09 01:28:51.078 pm infoDining room cupboard color mode is CT
dev:1082018-12-09 01:28:51.074 pm infoDining room cupboard saturation was set to 56%
dev:1082018-12-09 01:28:51.058 pm infoDining room cupboard hue was set to 23%
app:62018-12-09 01:28:26.043 pm debugInitializing
dev:1412018-12-09 01:27:39.789 pm infoKitchen Table color mode is RGB
dev:1412018-12-09 01:27:39.773 pm infoKitchen Table color temperature was set to 2257°K
app:12018-12-09 01:27:32.662 pm debugInitializing
dev:1262018-12-09 01:27:24.865 pm infoHue color lamp 2 color mode is CT
dev:412018-12-09 01:27:18.844 pm infoGroup Cinema color mode is RGB
dev:412018-12-09 01:27:18.818 pm infoGroup Cinema color temperature was set to 4348°K
dev:412018-12-09 01:27:14.080 pm infoGroup Cinema color mode is RGB
dev:412018-12-09 01:27:14.063 pm infoGroup Cinema color temperature was set to 4348°K
dev:412018-12-09 01:27:13.987 pm infoGroup Cinema color mode is RGB
dev:412018-12-09 01:27:13.985 pm infoGroup Cinema color temperature was set to 4348°K
dev:1252018-12-09 01:27:13.857 pm infoHue color lamp 1 color mode is CT
dev:402018-12-09 01:27:13.741 pm infoGroup En suite color mode is RGB
dev:402018-12-09 01:27:06.812 pm infoGroup En suite color mode is RGB
dev:432018-12-09 01:26:49.116 pm infoGroup Granary Guest Bedroom color mode is CT
dev:432018-12-09 01:26:49.095 pm infoGroup Granary Guest Bedroom color mode is CT
dev:382018-12-09 01:26:27.723 pm infoGroup Upstairs Hall color mode is CT
dev:422018-12-09 01:26:27.623 pm infoGroup Rose Room color mode is CT
dev:422018-12-09 01:26:27.621 pm infoGroup Rose Room saturation was set to 56%
dev:422018-12-09 01:26:27.618 pm infoGroup Rose Room hue was set to 23%
dev:382018-12-09 01:26:27.573 pm infoGroup Upstairs Hall color mode is CT
app:62018-12-09 01:26:16.274 pm debugInitializing
dev:422018-12-09 01:26:01.534 pm infoGroup Rose Room color mode is CT
dev:422018-12-09 01:26:01.532 pm infoGroup Rose Room saturation was set to 56%
dev:422018-12-09 01:26:01.530 pm infoGroup Rose Room hue was set to 23%
dev:422018-12-09 01:25:59.072 pm infoGroup Rose Room color mode is CT
dev:422018-12-09 01:25:59.070 pm infoGroup Rose Room saturation was set to 56%
dev:422018-12-09 01:25:59.019 pm infoGroup Rose Room hue was set to 23%
app:12018-12-09 01:25:22.431 pm debugInitializing
dev:52018-12-09 01:25:15.340 pm infoGranary 3 color mode is RGB
dev:52018-12-09 01:25:15.306 pm infoGranary 3 color temperature was set to 4348°K
dev:52018-12-09 01:25:15.277 pm infoGranary 3 color mode is RGB
dev:52018-12-09 01:25:15.270 pm infoGranary 3 color temperature was set to 4348°K
dev:52018-12-09 01:25:14.944 pm infoGranary 3 color mode is RGB
dev:52018-12-09 01:25:14.938 pm infoGranary 3 color temperature was set to 4348°K
dev:42018-12-09 01:25:07.611 pm infoGranary 2 color mode is RGB
dev:42018-12-09 01:25:07.569 pm infoGranary 2 color temperature was set to 4348°K
dev:42018-12-09 01:25:07.353 pm infoGranary 2 color mode is RGB
dev:42018-12-09 01:25:07.351 pm infoGranary 2 color temperature was set to 4348°K
dev:32018-12-09 01:24:59.434 pm infoGranary 1 color mode is RGB
dev:32018-12-09 01:24:59.432 pm infoGranary 1 color temperature was set to 4348°K
dev:32018-12-09 01:24:59.368 pm infoGranary 1 color mode is RGB
dev:32018-12-09 01:24:59.366 pm infoGranary 1 color temperature was set to 4348°K
dev:302018-12-09 01:24:59.361 pm infoRose Room 3 hue was set to 23%
dev:302018-12-09 01:24:38.627 pm infoRose Room 3 color mode is CT
dev:302018-12-09 01:24:38.623 pm infoRose Room 3 saturation was set to 56%
dev:302018-12-09 01:24:38.619 pm infoRose Room 3 hue was set to 23%
dev:1472018-12-09 01:24:21.107 pm infoLounge Tiffany Lamp color mode is CT
dev:1472018-12-09 01:24:21.102 pm infoLounge Tiffany Lamp saturation was set to 80%
dev:1472018-12-09 01:24:21.090 pm infoLounge Tiffany Lamp hue was set to 12%
dev:302018-12-09 01:24:21.040 pm infoRose Room 3 color mode is CT
dev:302018-12-09 01:24:21.035 pm infoRose Room 3 saturation was set to 56%
dev:302018-12-09 01:24:20.994 pm infoRose Room 3 hue was set to 23%
app:12018-12-09 01:23:55.620 pm debugInitializing
dev:292018-12-09 01:23:22.024 pm infoRose Room 2 color mode is CT
dev:292018-12-09 01:23:22.023 pm infoRose Room 2 saturation was set to 56%
dev:292018-12-09 01:23:21.992 pm infoRose Room 2 hue was set to 23%
dev:292018-12-09 01:23:19.143 pm infoRose Room 2 color mode is CT
dev:292018-12-09 01:23:19.141 pm infoRose Room 2 saturation was set to 56%
dev:292018-12-09 01:23:19.140 pm infoRose Room 2 hue was set to 23%
dev:1502018-12-09 01:23:19.137 pm infoMaster bedroom 1 color mode is CT
dev:1502018-12-09 01:23:19.135 pm infoMaster bedroom 1 saturation was set to 55%
dev:1502018-12-09 01:23:19.133 pm infoMaster bedroom 1 hue was set to 13%
dev:1102018-12-09 01:22:37.304 pm infoFire Lightstrip color mode is CT
dev:282018-12-09 01:22:37.326 pm infoRose Room 1 color mode is CT
dev:282018-12-09 01:22:37.324 pm infoRose Room 1 color mode is CT
dev:282018-12-09 01:22:37.322 pm infoRose Room 1 saturation was set to 56%
dev:282018-12-09 01:22:37.321 pm infoRose Room 1 hue was set to 23%
dev:282018-12-09 01:22:37.304 pm infoRose Room 1 saturation was set to 56%
dev:282018-12-09 01:22:37.303 pm infoRose Room 1 hue was set to 23%
dev:1102018-12-09 01:22:37.303 pm infoFire Lightstrip saturation was set to 80%
dev:1102018-12-09 01:22:37.301 pm infoFire Lightstrip hue was set to 12%
app:62018-12-09 01:22:04.948 pm debugInitializing
dev:1652018-12-09 01:22:04.858 pm infoSnug Table color mode is RGB
dev:1652018-12-09 01:22:04.856 pm infoSnug Table color temperature was set to 2000°K
dev:272018-12-09 01:21:51.001 pm infoHue color spot 8 color mode is RGB
dev:272018-12-09 01:21:50.943 pm infoHue color spot 8 color mode is RGB
app:12018-12-09 01:21:50.711 pm debugInitializing
dev:262018-12-09 01:21:43.862 pm infoHue color spot 7 color mode is RGB
dev:262018-12-09 01:21:34.023 pm infoHue color spot 7 color mode is RGB
dev:1152018-12-09 01:21:33.925 pm infoHall Lamp color mode is CT
dev:252018-12-09 01:21:33.628 pm infoHue color spot 6 color mode is RGB
dev:252018-12-09 01:21:33.173 pm infoHue color spot 6 color mode is RGB
dev:242018-12-09 01:21:26.177 pm infoHue color spot 5 color mode is RGB
dev:242018-12-09 01:21:26.124 pm infoHue color spot 5 color mode is RGB
dev:232018-12-09 01:20:58.999 pm infoHue color spot 4 color mode is RGB
dev:232018-12-09 01:20:58.980 pm infoHue color spot 4 color mode is RGB
app:62018-12-09 01:20:58.665 pm debugInitializing
dev:1722018-12-09 01:20:58.015 pm infoGroup Outside color mode is RGB
dev:222018-12-09 01:20:57.975 pm infoHue color spot 3 color mode is RGB
dev:222018-12-09 01:20:51.406 pm infoHue color spot 3 color mode is RGB
dev:72018-12-09 01:20:38.752 pm infoGranary 6 color mode is RGB
dev:72018-12-09 01:20:38.741 pm infoGranary 6 color temperature was set to 4348°K
dev:72018-12-09 01:20:38.571 pm infoGranary 6 color mode is RGB
dev:72018-12-09 01:20:38.547 pm infoGranary 6 color temperature was set to 4348°K
dev:1712018-12-09 01:20:38.483 pm infoGroup Dining Room color mode is CT
dev:1712018-12-09 01:20:38.474 pm infoGroup Dining Room saturation was set to 56%
dev:1712018-12-09 01:20:38.452 pm infoGroup Dining Room hue was set to 23%
dev:212018-12-09 01:20:22.587 pm infoHue color spot 2 color mode is RGB
dev:1702018-12-09 01:20:22.467 pm infoGroup Master Bedroom color mode is CT
dev:1702018-12-09 01:20:22.459 pm infoGroup Master Bedroom saturation was set to 80%
dev:212018-12-09 01:20:22.443 pm infoHue color spot 2 color mode is RGB
dev:1702018-12-09 01:20:22.413 pm infoGroup Master Bedroom hue was set to 12%
dev:62018-12-09 01:20:22.036 pm infoGranary 5 color mode is RGB
dev:62018-12-09 01:20:22.034 pm infoGranary 5 color temperature was set to 4348°K
app:12018-12-09 01:20:19.725 pm debugInitializing
dev:62018-12-09 01:20:08.372 pm infoGranary 5 color mode is RGB
dev:62018-12-09 01:20:08.357 pm infoGranary 5 color temperature was set to 4348°K
dev:1692018-12-09 01:20:08.354 pm infoGroup Downstairs Hall color mode is CT
dev:1682018-12-09 01:19:57.702 pm infoGroup Kitchen color mode is CT
dev:1682018-12-09 01:19:57.689 pm infoGroup Kitchen saturation was set to 79%
dev:1682018-12-09 01:19:57.675 pm infoGroup Kitchen hue was set to 21%
dev:202018-12-09 01:19:57.597 pm infoHue color spot 1 color mode is RGB
dev:1672018-12-09 01:19:45.668 pm infoGroup Office color mode is CT
app:62018-12-09 01:19:45.452 pm debugInitializing
dev:1662018-12-09 01:19:18.034 pm infoGroup Lounge color mode is CT
dev:1662018-12-09 01:19:18.024 pm infoGroup Lounge saturation was set to 80%
dev:1662018-12-09 01:19:17.977 pm infoGroup Lounge hue was set to 12%
app:12018-12-09 01:19:06.172 pm debugInitializing
app:62018-12-09 01:18:07.402 pm debugInitializing
dev:12018-12-09 01:18:01.533 pm infoOnline
dev:1052018-12-09 01:18:01.530 pm infoOnline
dev:12018-12-09 01:18:01.526 pm infoOnline
app:12018-12-09 01:18:00.413 pm debugInitializing
app:62018-12-09 01:17:58.560 pm debugInitializing
app:12018-12-09 01:17:58.557 pm debugInitializing
Quick follow-up... the hub looks to be speeding up a bit - I presume more stuff is loaded into whatever memory it's got. The devices page, though, is still pretty darned slow, despite the fact that it's only got 114 entries in it. At this point, I'd be scared to add any more of the sensors, etc, into the system, although I suppose that numerically, the two hue bridges to represent the bulk of the devices. Still... I'm not going to get off ST at this rate.
-- Jules
Sorry for the troubles. Please check your PM for more details and updates. We are looking into your problem.
