[Re-release] Hubitat Ring Integration (Unofficial)
This app works great for me and exposes the alarm modes properly. I just tried the new built in integration, and although you can initiate a mode change via the integration, the mode can't be read or seen by any automation you set up, so its presently useless for me.
I have started seeing the following warnings in my logs:
apiRequestTickets (retryable) http error: 408, Connect to prd-api-us.prd.rings.solutions:443 [prd-api-us.prd.rings.solutions/52.21.120.109, prd-api-us.prd.rings.solutions/23.20.28.222, prd-api-us.prd.rings.solutions/3.211.186.78, prd-api-us.prd.rings.solutions/52.72.232.85, prd-api-us.prd.rings.solutions/3.212.48.92, prd-api-us.prd.rings.solutions/184.73.185.109] failed: Network is unreachable (connect failed), null
When this happens, I also see this error starting to show up:
PM
Cannot send request because socket is not connected: {"channel":"message","msg":{"dst":"redacted","msg":"DeviceInfoDocGetList","seq":1}}
It seems to happen whenever my router goes offlines for a bit. (I've been taking it offline to do some upgrades).
It seems to resolve if I "Initialize" the location device and then reboot the hub.
In a similar timeframe I upgraded to hubitat platform version 2.5.0.126.
Is this to be expected?
Marc
After my recent hub update to 2.5.1, my Unofficial Ring App has been really wonky.
I see this in the logs:
This is what happens when I do an "initialize"
The hub is not reliably getting events from Ring now.
...Rob
Hi @rob9 DId you figure out what was going on?
I'm thinking of doing an update and it would be good to know if it's going to break the integration.
Thanks!
Marc
I ended up doing an "initialize" and a "refresh" on the API and it has seemed to resume behaving normally. Not entirely sure about the logs because I didn't look once it started acting right. lol
FYI - I created a significant update on latest model support, and making it easier for me to find a new device when I add it.
The PR against this code is here, and you can get the full file for an easy copy past here in my fork;
What I added: Added support for 13 newer/missing Ring device kinds + better logging for unrecognized devices
1. New device kinds added to DEVICE_TYPES
Cross-referenced against Ring's actual API kind values (via the python-ring-doorbell project's const.py, which tracks these closely) and added the ones (13 total) missing from this app's map:
kind Device Driver
cocoa_camera_v2 Ring Stick Up Cam Plus Ring Virtual Camera with Siren
cocoa_camera_v3 Ring Stick Up Cam Pro 4k Ring Virtual Camera with Siren
cocoa_doorbell_v2 Ring Video Doorbell Pro 4k Ring Virtual Camera
cocoa_doorbell_v5 Ring Video Doorbell 2023 Ring Virtual Camera
cocoa_doorbell_v6 Ring Video Doorbell 2023 Ring Virtual Camera
cocoa_floodlight_v2 Ring Floodlight Pro 4k 2 Ring Virtual Light with Siren
cocoa_spotlight_v2 Ring Spotlight 2K Pro Ring Virtual Light with Siren
chime_v4 Ring Chime (2nd Gen) Ring Virtual Chime
doorbot Ring Video Doorbell (legacy kind string) Ring Virtual Camera
df_doorbell_clownfish Ring Video Doorbell (Battery) Ring Virtual Camera
stickup_cam_mini_ptz_v1 Ring Indoor Cam Pan-Tilt Ring Virtual Camera with Siren
hexa_camera_2_v1 Ring Elite Cam Gen 2 (140°) Ring Virtual Camera with Siren
hexa_camera_6_v1 Ring Elite Cam Gen 2 (360°) Ring Virtual Camera with Siren
Note: intercom_handset_audio / intercom_handset_video (Ring Intercom) are not included.
2. Unsupported devices are now actually visible in the logs
Previously, if Ring returned a device whose kind wasn't in DEVICE_TYPES, it was silently skipped — logged only via logDebug, which is off by default. You'd never know a device existed unless you happened to have debug logging on and went looking.
Now:
  • Each unrecognized device logs a log.warn (visible without any logging toggles) with its kind, Ring's description, id, and location_id.
  • After a full device-discovery scan, a summary line lists every unrecognized kind found in that pass.
Example output:
warn loadAvailableDevices: Unrecognized device kind 'stickup_cam_mini_ptz_v1' (description: 'Backyard Cam', id: 12345678) at location abc-123. Add an entry for kind 'stickup_cam_mini_ptz_v1' to DEVICE_TYPES to support it.
warn loadAvailableDevices: Found 1 unrecognized device(s) not supported by this app: kind='stickup_cam_mini_ptz_v1' (Backyard Cam)
3. Catches entirely new Ring device categories, not just new kinds
apiRequestDevices() only ever pulled devices out of six known top-level JSON keys (authorized_doorbots, base_stations, beams_bridges, chimes, doorbots, stickup_cams). If Ring ever ships a device under a brand-new category key, it wouldn't just fail to match a kind — it would never even be scanned, and you'd have no idea it existed.
Now, the app compares the response's top-level keys against the known list and logs (via logDebug) any it doesn't recognize, e.g.:
apiRequestDevices: Response contains unrecognized top-level device category key(s) [other] which are not being scanned for devices. Devices under these keys will not show up in device discovery.
tl;dr: if a device wasn't showing up for you before, turn on debug logging (or just check for warnings after a Discover Devices run), and if you see a kind string that isn't in DEVICE_TYPES, you can now spot it easily and either add it yourself or report it here and we can add it quickly.
That sounds sweet!
Think it might make it into the HPM version?
I don't know. someone with access to that repository would need to accept the PR.
Not sure who that is these days @ardichoke @morse.caleb ?
My goal here is just to keep this up to date as the official integration matures and there are clean ways for people to migrate over. Then potentially this app or another companion app could complement any gaps from the official app.
I certainly appreciate that!
I've got the Ring stuff pretty deeply embedded in my automations--so changing would be a royal PITA.
Plus, the built-in integration seems to be a long ways from catching up with the capabilities in this app in at least some of the ways I use it. But, the built in app is maturing quite a bit.
Hi @rob9, I tried the built-in app sometime back and it had several issues. I've also noticed that the official beta thread has gone silent with no responses to issues. Is there another active thread somewhere?
Marc
Not sure how they are coming.
I'm satisfied with this community app, so I'm not excited about changing.
With the solid community app, it was enlightening to see how many people suddenly started using Ring integration even though this one has been around forever.
I'm wondering if Ring changed the API again.
I'm not seeing the contact sensor changing and a refresh doesn't fix it, either:
This may have been because the Ring Alarm made station went offline. Not sure what's going on, but it's been dropping off my LAN a lot lately (hard wired connection).
I just moved my integration from this to the Official (but still beta) integration. I had tried the new one before but had some issues so I paused for a bit. I, too, hadn’t seen much in the way of updates but I went ahead and tried the official integration again about 2 weeks ago. I have been very happy with it. All my devices popped right up, even things like lighting and the alarm retrofit kit; although I don’t use their camera so cannot speak to that. It was a bit of a pain to update all my rules but happy to be using the go forward solution. (My fingers are firmly crossed now that I have tempted fate with this post.)
All of my contacts are still working fine, but I am seeing that event warnig on "evenito", it seems additive and not a change.
Are your contacts still not performing?
I think that was an issue with my base station. Not sure why, but it was going offline and onto cellular backup for no good reason (it was plugged into to a ethernet cable and it took a reboot to force it to connect again. smh.
Sorry
So. I'm getting a new Ring base station.
Any tips on swapping it out (I've got cameras, chimes, smoke alarms, contact sensors, sirens, motion sensors, etc.
Going from an old Gen 1 to a Gen 2
Take good notes / screenshots would be my advice… I suspect you’ll have to re-do all the routines if you have any in Alexa, and then on the Hubitat side, likely will need to touch everything that is integrated to it…
So.
Several hundred things, many dozens of rules, and weeks of effort. :sad_but_relieved_face:
I was afraid of that.
Yea… Not looking forward to the day I’ll have to do the same - for the same reason!
Anybody know if swapping my new base station out for the new one will delete my old ring devices?
Ideally, they'd stay around until I manually delete them.
