RBGW bulb lost connection
Zigbee Sylvania bulb reset I think. Power was out to switch for a couple hours which normally doesn't effect it. But today it did. Any easy way to get it re-connected or do I have to delete device and re-add? Any tips on getting it to fall back in line with rule machine, etc or will I have to re-do those also?
With a Zigbee device if you just pair it again it should recognize it and say it found a previously discovered device or something to that effect. Should not have to re-do anything.
If not then yeah, you will have to set everything back up.
YES!!!! Thank you! You were correct and I didn't need to do anything. The message that comes across after pairing is, "Found Previously Joined Device".
