Random problem with KASA dimmers
I have been using 4 KASA dimmers for about the past year (C8 Hubitat with Kasa Integration). Occasionally (perhaps every couple of days), I cannot turn on or off one the devices using Hubitat or Alexa. Which device falls prey to this problem is random. However, if I change the dimmer level through Hubitat or Alexa, the new dimmer level is then properly accepted and the lights may now be turned on or off.
Has anyone else experience this? Any suggestions?
Thanks,
Craig
First, make sure the Kasa firmware is up to date (via the Kasa App). TP-Link had some wifi disconnect problem with some devices and (I believe) the latest versions now work.
Second, make sure the dimmers have Static IP Addresses (DHCP Reservations) in your wifi router.
