I am using the Hubitat Rachio integration with a Gen 2 8-zone controller (model 7F4D00).
I created a Rule Machine rule called "Stop Sprinklers" that is triggered by a virtual switch.
The issue is that I cannot find a Rule Machine action that reliably stops an active watering zone.
What I have tested:
Starting zones from Hubitat works.
Water All Rule works.
On the Zone 1 device page, the "Stop Watering" command works.
In Rule Machine, using Off on the zone devices does not stop watering.
In Rule Machine, using a Custom Action with stopWatering() on the zone device does not stop watering.
On the controller device, Stop Watering changes status to off but does not stop the active zone.
Question:
For Hubitat Rule Machine, what is the correct command or custom action to immediately stop an active Rachio watering run from a virtual switch?
Are there specific controller commands that should be used instead of Off or stopWatering()?
I installed Rachio through HPM. Hubitat version 2.5.0.157.
My logs repeatedly show: “Invalid Signature on received webhook. Ignoring.”
Starting zones works, but stopWatering()/Stop Watering does not reliably stop an active manual run from Rule Machine.
Is this a known issue with the community Rachio integration? Do I need to re-authenticate, recreate the webhook, or switch to the built-in Rachio integration?
