Quibino relay not responding to zwave commands
Hi,
I installed a Quibino Flush 1 Relay a few days ago. Got it connected, and it worked fine for a couple of days. Today it seems to have stopped receiving commands. Sending it on or off doesn't do anything. The device status page in Hubitat shows "pendingSwitch : on" or "off" when sending it the command, but nothing happens at the relay and the actual status never updates in hubitat. When I shut off power at the breaker and then turn it back on, hubitat immediately recognizes it (it seems to get the energy and power levels, and also clears the "pendingSwitch" setting), so Hubitat seems to receive data from the relay, it just isn't responding to the on/off commands.
The relay is installed behind an outlet and there's no physical switch wired into the relay. This makes it difficult to try re-pairing/excluding, as all the instructions are about toggling the switch to get it into pair mode.
Anything else to try before opening the outlet back up and needing to pull the thing out?
