My first attempt at doing a driver in Hubitat..
With some help here (thanks tomw!) I quickly got a trivial driver working for controlling my old x10 devices via a raw socket interface to the existing mochad server. for reference, it is pasted below.
But, I have some questions about the Raw Socket interface.
The signature for the connect method has no return. I'd expect a "handle" of some sort to be used for subsequent sendMessage invocations. I think this implies there can be one and only one raw socket connection?
When should the connect be done? I did it in a capability "Initialize", but I don't know if that makes sense, or when "Inititalize" will be called. For testing, I'm just clicking on Initialize where the device prefs and buttons for on and off are presented.
When should the close be done? I do a close in Initialize before doing the connect. Should I invoke close somewhere else?
There is no feedback about success when the connect is done. Should socketStatus I provided be called to indicate success or failure of the connection attempt?
parse IS called when a response is sent from the connected (mochad) server. When I log it, it looks like this:
dev:842021-05-27 08:58:39.053 am debug30352F32372030383A35383A333820547820524620486F757365556E69743A2041342046756E633A204F66660A
The response looks like this when I send the message using netcat (nc):
05/27 08:29:23 Tx RF HouseUnit: A4 Func: Off
So, apparently, parse is getting called with a string that is the ascii version of the string. Should I check the groovy docs for how to convert it, or should I use a different signature for my implementation of parse"
Thanks!
The driver code follows...
def version() {"v0.1"}
import hubitat.helper.InterfaceUtils
metadata {
definition (name: "X10 via MochaD", namespace: "Flying-Nerd", author: "Dave Thomas") {
capability "Switch"
preferences {
input("ip", "text", title: "IP Address", description: "[IP Address of your mochad server", required: true)
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
input name: "station", title:"X10 Station", description: "X10 Station ID"
input name :"port", title:"Mochad port", type:"text", description: "Port for Mocha Server", required:true
void updated() {
log.info "Updated..."
void installed() {
log.info "Installed..."
refresh()
def refresh() {
def Close() {
if (logEnable) log.debug "closing socket"
interfaces.rawSocket.close()
def on() {
if (logEnable) log.debug "Sending on request to [${settings.ip}], station ${settings.station}"
sendEvent(name: "switch", value: "on", isStateChange: true)
interfaces.rawSocket.sendMessage("rf ${settings.station} on\n")
//refresh()
def off() {
if (logEnable) log.debug "Sending off request to [${settings.ip}, station ${settings.station}]"
sendEvent(name: "switch", value: "off", isStateChange: true)
interfaces.rawSocket.sendMessage("rf ${settings.station} off\n")
//refresh()
def initialize() {
if (logEnable) log.info "initialize() called"
Close()
interfaces.rawSocket.connect(ip, port.toInteger())
//refresh()
def socketStatus(String message) {
if (logEnable) log.info "socketStatus() called"
log.info message
if (logEnable) log.info "parse called"
if (logEnable) log.debug(description)
