Difficulty or ease aside, it will break a lot of existing rules designed on the basis of the current documentation (which you admit to not having read).
So I hope @bravenel will take that into consideration while implementing any possible changes.
(If there is no relationship between the trigger events and events that would affect the required expression, you can use it that way, too; or you can use conditions in your rule actions, conditional triggers, or a variety of other means that may meet your needs too. This particular example is just one that is a nice illustration of the feature since, unlike many of those cases, it's harder to do any other way.)
I don't know what you mean, what trick??? Required Expressions are completely separate from triggers, except in one special case (device or variable in both Required Expression and trigger).
Ok, I just ran a couple of tests on this. The first test was the example from the docs:
Required expression = Mode is day
Trigger = Mode becomes Evening
When mode changes from Day to Evening it runs the rule actions, just like the docs say
However, I used the same rule for the second test, but changed it to be:
Required expression =(hub) variable < 2
Trigger = variable is 2
When the variable changes from 1 to 2, the rule actions do not run. So, to me it looks like required expression isnāt consistent in when it prevents the rule from running and when it doesnāt.
Edit: To be even more like the mode example I changed the variable example to instead have:
required expression = variable = 1
But the outcome was the same. Rule actions were not run when variable changed from 1 to 2
The simplest answer is : improved and more predictable timing. @aaiyar@hubitrep
I don't see what could be wrong if the Required Expression is evaluated the same way as the Conditional Trigger does:
On the Trigger event the Required Expression is evaluated and if true the Actions are running. This is a behavior of a Conditional Trigger and it works very reliably (so far did not seen any failure). The slider "Evaluate the Required Expression on startup" could be retired because each Trigger will evaluate it and present very fresh up to time state of the Required Expression. What is wrong with this picture? Do you really want a Required Expression to present an incorrect state?
The improved timing for Run Actions has nothing to do with anything in this topic.
The Required Expression can have its state change independently of any triggers, and if that happens it is evaluated then, and the result stored in atomic state.
The reason the approach is what it is stems from a desire NOT to evaluate the Required Expression when there is no reason to (i.e., upon events that will not change its value), and to not waste CPU for triggers when Required Expression is false (removed triggers). The Required Expression evaluation result is stored in atomic state in the app. This value can be looked at in lieu of re-evaluating the required expression. Are you hypothesizing that the independent evaluation results in timing problem, where result of evaluation happens after the trigger event? If that is the case, there is no fix possible. Or are you contemplating some other timing problem?
This is a non-sequitur. Complexity of the platform is not leading to "longer uncontrolled delays". You provide no evidence to support this claim.
Say what? That's a pretty wild accusation. Come on, how about sticking to facts?
Yeah, there was a bug that resulted in slow performance of certain actions (now fixed), but there are not other "timing related failures" that have been reported.
This is 100%+ true. I am talking about timing between evaluation of the Required Expression and Trigger events. The very good example is using a PB for preventing unwanted re-triggering. I had many cases when PB was set to FALSE as a very first ACTION but the Required Expression became FALSE near the end or even after the rule was executed. Because of that I stopped to use a PB for preventing unwanted multiple triggers.
If the RE is/was evaluated similarly to the CT this should work as expected.
Is not it?
These two statements above is kind of contradictive (the way I am reading them and trying to understand correctly).
Requied Expressions are going to be evaluated whenever an event occurs that might change the evaluation. When RE becomes false, all trigger subscriptions go away (except overlap triggers), so for the duration of falseness, no CPU is spent on triggers. Meanwhile, if a trigger is completely unrelated to RE, why evaluate the RE upon the trigger? RE has a known state that is not timing dependent in that case.
So that leaves the overlap case. Is that what you are concerned about? Case where trigger and Required Expression use same device or variable?
I'm not sure what specifically you are referring to, but there is a bug in the released platform with respect to variables used in both Required Expression and as trigger. Your link goes to a discussion about what happens in that case, but that discussion isn't informed by the existence of the bug.
Ok. So itās confirmed that there is a bug with how variables are used in that scenario then? So once the bug is resolved, the variable scenario should behave as the mode scenario? If so, Iām no longer confused
Every extra added commands requires extra CPU time. Is not this obvious?
This is based on my long time experience with designing HW with embedded CPUs. The SW team is/was always optimistic they can do everything in SW but eventually screaming about adding HW support for time critical functions. Thanks to the FPGA technology usually this could be done without costly modification the the existing boards.
I am glad, the bug was found fixed.
Based on my primary job experience when SW complexity is increased sooner or later it will be an impact on a system performance. And as usually SW will ask for more memory, faster processors and moving some functionality to the HW domain. It is what it is.
I am still using only the RM as my main Automation tool. But all my new rules as well as many existing are rewritten as a SMs. I was an idiot not to use SMs right away.
Of course, but you make a sweeping comment not based on facts. A larger software base does not mean a slower one necessarily. In fact, the hub platform has grown with every release, and yet many releases make it faster. Hmmm...
So, not based on Hubitat Elevation, but other systems. Come on, that's ridiculous ...
This is not about Hubitat. so why post it? Being long time EE doesn't excuse you from need to make correct and relevant posts. I suggest that you stop making sweeping accusations about the hub that are not supported by facts, logs, etc. Of course there are bugs found from time to time, and we fix them as soon as we can. But the hub is not going down some timing hole as you suggest.
