Hello All
I recently converted from Smartthings and starting to develop more complex rules. I'm getting the learning curve down from the two different products but encountered a problem. I created a rule to turn on our bedroom lights at 40% if a few things occur (mode, lux, tv off, lamps already off). I basically want to the lights to turn on if nobody is in the room. Everything is working up until I get to the Actions to Run event. My two hue lamps are not turning on. I currently have it set to Switch On and then Dim. Is there a better way on turning on a Hue light bulb? I thought the correct way in Hubitat was On/Off for Hue lights?
