Question on EZ dasboard
Hi I'm setting up some items with the new EZ dashboard (great add on thanks).
Question is in the older version of dashboard I could set up icons for each room going into a room and also had an icon to go back to main dashboard. Can this be done in EZ dashboard?
I don't think they've added that yet...
Navigation options between pages are currently available by clicking on the navigation option at the bottom left of the EZ dashboards.
Displays navigation options - the Home and Back are built-in, you add other dashboards via the dashboard's settings.
Adding navigation to other dashboards:
Choose the option in the upper right to go to the dashboard setup page:
Select the "Edit" option for the dashboard:
2024-06-29 09_22_12-C8, C7, & Misc Hubs
Turn on the "Navigation To" option if it off, and select the navigation optoins you want for that dashboard:
2024-06-29 09_22_27-C8, C7, & Misc Hubs
Thanks for the reply that helps.
