Qubino ZMNHJD1 – Pilot Wire Module
Has anyone integrated this device to hubitat or any other system? I have a friend that this might be perfect for but he would need it to, just work as isn't into home automation "yet" :wink:
https://www.vesternet.com/mwdownloads/download/link/id/1382/
http://qubino.com/products/flush-pilot-wire/
@BorrisTheCat Did you event get to work this module?
I am also in the search for a Pilot Wire module.
It was for a friend and it was to see if it was possible but it's not been done yet. Have you brought one?
Most probably yes, I am first doing some investigations before i actually get one.
There should be no issue with getting it to connect the issue is I have seen no evidence of anyone doing and development on it. So you will need to build your own driver or ask nicely to get someone to build one for you. To do that they will need to be sent the device first. @mike.maxwell has already done some development on other qubino products but I don't know if qubino sent him their range or if it was products he already had/ was sent by others.
@BorrisTheCat, I have just got one of these and added it to Hubitat.
There is no official driver and i sent the msg to @mike.maxwell as you suggested and hopefully we can get something working.
I just started doing some test with hacked dimmer driver and using the method "setLevel" sends the corresponding order and its works. But its not production ready..
The hard part was finding the actual levels that should be sent for each "order", hopefully one has already done this:
@BorrisTheCat News!
Just finished the initial version of the driver and its working as expected, you can test it by your self:
https://raw.githubusercontent.com/syepes/Hubitat/master/Drivers/Qubino/Qubino%20Flush%20Pilot%20Wire.groovy
