I'm looking at adding a Qubino ZMNHID3 to monitor temp of a copper water supply pipe located in a crawlspace. The basic idea is that if the pipe temp is near 32 degrees, switch on the relay to power the heat tape, allow the temp to rise to say 36 degrees when switch off the relay. As an added bonus, the Qubino also monitors energy consumption which would come in handy to confirm that the heat tape is drawing power.
Can anyone confirm whether or not HE supports energy monitoring for this device?
How about energy monitoring? I'm hoping to be able to determine if the heat tape is working by seeing if it's drawing current. Power consumption should tell me if it's energized.
