Not that "Homebrew". I want a virtual button, that when pressed, does an HTTP GET to an URI specified in device preferences. I've subbed my driver code in for the default virtual button driver code, If I press the "push" button in the Commands pane of the device, what I expect to happen happens. But if I tap on the icon in a dashboard, nothing happens. Equally telling is that when I try to set up a RM rule to use this "button", if I select buttons as the action target, it doesn't show up.
I'm pretty sure this is because a button device has some capability I don't have in my driver. I started out with just "Actuator", have added "Switch", and now the dashboard icon shows up as a switch, and presumably since I have only implemented a "push" command, pressing that also does nothing.
I can get past this by just making this thing a switch, and changing commands to provide on/off. But am trying to get my head wrapped around what it would take to do this "button". I took a look over in the developer driver section, and feel like this is way below the level of knowledge and wherewithal I saw there.
Any hints greatly appreciated.
--Richard
