Pushover double messages
I've just started using pushover but every event is doubled up so i get two messages on my phone.
dev:3592018-09-21 13:33:13.020:infoSending Message: [Rule Back door open True] Priority: [0] to [All Devices]
dev:3592018-09-21 13:33:11.311:infoSending Message: [Rule Back door open True] Priority: [0] to [All Devices]
dev:3592018-09-21 12:49:51.301:infoSending Message: [Rule Back door open True] Priority: [0] to [All Devices]
dev:3592018-09-21 12:49:49.305:infoSending Message: [Rule Back door open True] Priority: [0] to [All Devices]
I see that you have selected [All Devices] in the log message. I'm going to guess that you have two pushover devices setup? Make sure within each device you have selected a different user (device name) in the preference section of each HE pushover device.
If you didn't select a user (device name) in each pushover device, it will send the message to all.
Only currently have one pushover device on hubitat, but select my device name in driver anyway and that seems to have solved the problem. many thanks @bptworld
