I am having a tough time getting push out notifications on my IPhone. I have it set up in notifications on both the phone and my hub, but can't get the push notifications to work when my sensors are triggered. I must be missing a step. Can anyone send a step by step process? I did follow the directions from Hubitat? Thanks in advance!
Make sure notifications are allowed on iphone for that app. Your phone should also be listed in devices on the device page. You can delete that and log out of the app then when you log in and select hub it will be recreated and see if that helps. If none of the above work, I would reccomend pushover. It works flawlessly and has native support in HE (wonkiness in the built in notifier was why I moved to Pushover in the first place)
