@bravenel, not sure if this is reported yet or not since I couldn't find a topic about this issue. If I use the Push Button Per Mode option on a new Rule or Trigger, I'm getting an error:
Screenshot example before that error occurs:
I can replicate with my Pico remotes doing it the same way so it has nothing to do with Life360. If i do just the Push button option, it works fine but not with Push Button Per Mode. It replicates 100% of the time for me regardless of how I setup the Rule events and if it's a Rule or a Trigger. It seems the button number option might be missing, not sure if that's what's causing the error.
Logs from this example:
app:6472019-06-09 11:41:22.042 pm errorgroovy.lang.MissingMethodException: No signature of method: java.lang.String.call() is applicable for argument types: (java.lang.String, org.codehaus.groovy.runtime.GStringImpl, java.lang.Boolean, java.util.LinkedHashMap) values: [Vacation Mode, butM10True.1, true, [push:Push]] Possible solutions: wait(), any(), trim(), size(), find(), next() (selectActionsTrue)
