This probably shows my ignorance, but is there any way to pull the temperature out of my echo plus (zigbee hub) to use in HE? I know I can do a scrappy solution in IFFT or through virtual switches if I'm just looking for a threshold temp as a trigger, but was curious if some other more direct solution was available?
I cannot think of any way to do this. Why not pair your temperature sensor directly to Hubitat instead?
The echo plus contains a temperature sensor and shows as a device in Alexa. I'm trying to avoid putting another temperature sensor in the room that echo is in.
Ahhh, that makes sense.
