This is a community driver for the Lightify 4 Button Switch. This ZigBee switch (Model 74099 and made under the OSRAM and Lightify brands) provides 4 physical buttons that can be pressed, held, double tapped, and released. The driver also allows for a number of presses so you know if the same button has been pressed (with a configurable maximum/roll over value).
This driver (nor device) is not new, it was originally part of work I did with my Securifi drivers project thread that has been closed for some time now. I made a series of updates to this driver (and it is not a Securifi product) while I was building it into some Rules tonight. So, I thought it would be a good time to make sure the update was available for whoever might want it.
As with all of my drivers, it will schedule a daily check to see if there is an update available and will populate the “DriverStatus” if there is (but does not update itself of course). You can perform an Import from with the Hubitat driver code page, or copy/paste over it by going to the link. At this time it is not loaded into my HPM list (I expect there will be little demand for this driver considering it’s past downloads in the previous thread) but that could change if there is demand.
The driver can be located here:
https://www.drdsnell.com/projects/hubitat/drivers/Lightify4Button.groovy
