Small caveat the driver I use for my tesla vehicle is ALSO called TeslaConnect not sure if that will pose and issue down the road.
Ok updated.
dev:6432020-05-20 11:18:19.683 amdebugTesla Powerwall - Device data = {"enumerating":false,"updating":false,"checking_if_offgrid":false,"running_phase_detection":false,"phase_detection_last_error":"phase detection not run","bubble_shedding":false,"on_grid_check_error":"on grid check not run","grid_qualifying":false,"grid_code_validating":false,"phase_detection_not_available":true,"powerwalls":[{"Type":"","PackagePartNumber":"1092170-53-J","PackageSerialNumber":"TG119177001SJ6","type":"acpw","grid_state":"Grid_Uncompliant","grid_reconnection_time_seconds":0,"under_phase_detection":false,"updating":false,"commissioning_diagnostic":{"name":"Commissioning","category":"InternalComms","disruptive":false,"inputs":null,"checks":[{"name":"CAN connectivity","status":"fail","start_time":"2020-05-20T11:18:20.736063992-07:00","end_time":"2020-05-20T11:18:20.736067658-07:00","message":"Cannot perform this action with site controller running. From landing page, either "STOP SYSTEM" or "RUN WIZARD" to proceed.","results":{},"debug":{}},{"name":"Enable switch","status":"fail","start_time":"2020-05-20T11:18:20.736069992-07:00","end_time":"2020-05-20T11:18:20.736072325-07:00","message":"Cannot perform this action with site controller running. From landing page, either "STOP SYSTEM" or "RUN WIZARD" to proceed.","results":{},"debug":{}},{"name":"Internal communications","status":"fail","start_time":"2020-05-20T11:18:20.736074325-07:00","end_time":"2020-05-20T11:18:20.736076658-07:00","message":"Cannot perform this action with site controller running. From landing page, either "STOP SYSTEM" or "RUN WIZARD" to proceed.","results":{},"debug":{}},{"name":"Firmware up-to-date","status":"fail","start_time":"2020-05-20T11:18:20.736078658-07:00","end_time":"2020-05-20T11:18:20.736080658-07:00","message":"Cannot perform this action with site controller running. From landing page, either "STOP SYSTEM" or "RUN WIZARD" to proceed.","results":{},"debug":{}}]},"update_diagnostic":{"name":"Firmware Update","category":"InternalComms","disruptive":true,"inputs":null,"checks":[{"name":"Powerwall firmware","status":"not_run","start_time":null,"end_time":null,"progress":0,"results":null,"debug":null},{"name":"Battery firmware","status":"not_run","start_time":null,"end_time":null,"progress":0,"results":null,"debug":null},{"name":"Inverter firmware","status":"not_run","start_time":null,"end_time":null,"progress":0,"results":null,"debug":null},{"name":"Grid code","status":"not_run","start_time":null,"end_time":null,"progress":0,"results":null,"debug":null}]},"bc_type":""},{"Type":"","PackagePartNumber":"1092170-53-J","PackageSerialNumber":"TG1191780004MS","type":"acpw","grid_state":"Grid_Uncompliant","grid_reconnection_time_seconds":0,"under_phase_detection":false,"updating":false,"commissioning_diagnostic":{"name":"Commissioning","category":"InternalComms","disruptive":false,"inputs":null,"checks":[{"name":"CAN connectivity","status":"fail","start_time":"2020-05-20T11:18:20.736440656-07:00","end_time":"2020-05-20T11:18:20.736443989-07:00","message":"Cannot perform this action with site controller running. From landing page, either "STOP SYSTEM" or "RUN WIZARD" to proceed.","results":{},"debug":{}},{"name":"Enable switch","status":"fail","start_time":"2020-05-20T11:18:20.736446656-07:00","end_time":"2020-05-20T11:18:20.736448656-07:00","message":"Cannot perform this action with site controller running. From landing page, either "STOP SYSTEM" or "RUN WIZARD" to proceed.","results":{},"debug":{}},{"name":"Internal communications","status":"fail","start_time":"2020-05-20T11:18:20.736450989-07:00","end_time":"2020-05-20T11:18:20.736452989-07:00","message":"Cannot perform this action with site controller running. From landing page, either "STOP SYSTEM" or "RUN WIZARD" to proceed.","results":{},"debug":{}},{"name":"Firmware up-to-date","status":"fail","start_time":"2020-05-20T11:18:20.736455322-07:00","end_time":"2020-05-20T11:18:20.736457322-07:00","message":"Cannot perform this action with site controller running. From landing page, either "STOP SYSTEM" or "RUN WIZARD" to proceed.","results":{},"debug":{}}]},"update_diagnostic":{"name":"Firmware Update","category":"InternalComms","disruptive":true,"inputs":null,"checks":[{"name":"Powerwall firmware","status":"not_run","start_time":null,"end_time":null,"progress":0,"results":null,"debug":null},{"name":"Battery firmware","status":"not_run","start_time":null,"end_time":null,"progress":0,"results":null,"debug":null},{"name":"Inverter firmware","status":"not_run","start_time":null,"end_time":null,"progress":0,"results":null,"debug":null},{"name":"Grid code","status":"not_run","start_time":null,"end_time":null,"progress":0,"results":null,"debug":null}]},"bc_type":""}],"has_sync":true,"sync":{"updating":false,"commissioning_diagnostic":{"name":"Commissioning","category":"InternalComms","disruptive":false,"inputs":null,"checks":[{"name":"CAN connectivity","status":"fail","start_time":"2020-05-20T11:18:20.736638654-07:00","end_time":"2020-05-20T11:18:20.736641988-07:00","message":"Cannot perform this action with site controller running. From landing page, either "STOP SYSTEM" or "RUN WIZARD" to proceed.","results":{},"debug":{}},{"name":"Firmware up-to-date","status":"fail","start_time":"2020-05-20T11:18:20.736644321-07:00","end_time":"2020-05-20T11:18:20.736646321-07:00","message":"Cannot perform this action with site controller running. From landing page, either "STOP SYSTEM" or "RUN WIZARD" to proceed.","results":{},"debug":{}}]},"update_diagnostic":{"name":"Firmware Update","category":"InternalComms","disruptive":true,"inputs":null,"checks":[{"name":"Synchronizer firmware","status":"not_run","start_time":null,"end_time":null,"progress":0,"results":null,"debug":null},{"name":"Grid code","status":"not_run","start_time":null,"end_time":null,"progress":0,"results":null,"debug":null}]}},"states":[]}
dev:6432020-05-20 11:18:19.427 amdebugTesla Powerwall - Device data = {"status":"StatusUp","running":true,"connected_to_tesla":true}
dev:6432020-05-20 11:18:19.423 amdebugTesla Powerwall - Device data = {"grid_status":"SystemIslandedActive","grid_services_active":false}
dev:6432020-05-20 11:18:19.396 amdebugTesla Powerwall - Device data = {"privacy_notice":true,"limited_warranty":true,"grid_services":true,"marketing":true,"registered":true,"timed_out_registration":false}
dev:6432020-05-20 11:18:19.389 amdebugTesla Powerwall - Device data = {"percentage":66.63141773628938}
--- Live Log Started, waiting for events ---
