0.7.0 has just one real change, but it should be a really nice one for those that want to use it:
It includes an initial version of the HTML Template method that @anon81541053 figured out. This allows someone to go into the sensors (the CHILD device, not the parent) and enter an HTML string complete with variable names in a preference.
That can then be used as an attribute on your dashboard. So if you want temperature and humidity both displayed, enter something like: <p>Temperature: ${ temperature }°${ location.getTemperatureScale() }</p><p>Humidity: ${ humidity }%</p>
This is an initial test of how this works and if people find it useful, so feedback is appreciated. I have included the steps to use it in the driver itself.
@snell Are you going to continue to develop these drivers? I notice that Mircolino is developing a similar set of drivers for the Ecowitt GW1000 and the sensors. I was curious because the main difference between the two is that you have included the pws data as well. Is that true or not? Are you guys thinking of combining or anything like that?
I am definitely continuing to develop all my drivers. The only one "close" to pasture is the original AmbientWeather one because I think the newer AmbientEcowittWeather is far superior.
@anon81541053 has a lot more experience in development than I do, so his work has definitely been eye-opening for me, but I still feel mine has value (plus it all helps Ambient API users as well).
I also have a lightning and leak sensor on order, so I will incorporate those as soon as possible.
I did not NEED a leak sensor (I have a couple Fibaro ones around on the hub directly). But I was already ordering the lightning sensor and saw the leak sensor was also on sale (and supported by GW1000) so I decided to add that as well.
I got my Ecowitt GW1000 Tuesday and got it up and running with your AmbientEcowittWeather driver yesterday. The documentation you provided in the driver comments were very necessary and helpful. Thanks again for the work you do on these drivers.
A few questions for those who have more experience with the GW1000. How much data is being stored on the HE device - is it only the most recent set of readings or is history being stored as well? Any lessons learned about the best placement for the GW1000? It obviously needs to be in RF range (about 300 feet?) of the AW 2902A and any other sensors, but are there any other considerations?
I think HE is only storing the last values sent, plus maybe any logs and events. I would not set the GW1000 to send data more than once a minute. You can hook the GW1000 up to ecowitt.net if you want to see/track the data long term. You can also integrate it with WeeWX for other things.
As for location, I plugged mine in kinda central to the sensors I'm using. It's pretty far from the WS-2902 but only through windows. The other sensors are on different floors and rooms through walls and they are working fine. I would not worry about how close it is to your HE or WiFi router as they operate on different frequencies.
I think in the Ecowitt App, under "Sensors ID" you can see the signal strength... or maybe that is just a picture showing it's connected.... since it has bars, I feel like it's the strength... but all of mine have all the bars...
I can say that my driver has no mechanism to store data over time. It provides the most recent it has received (in Ecowitt's case) or the most recent it has polled (for Ambient API, although disclaimer there, Ambient HAS returned data that is not actually the most recent due to server-side problems, in the past). I have no plans to start storing data over time as it could become huge quickly.
HE as a whole would have additional data in the logs (depending on your logging level) and in the device events history.
As for my positioning... My GW1000 is currently towards the middle of my house, lower level (we have a split level). Purely where there was a convenient USB port for power. No trouble with signal despite that room being electronically "noisy". The ws2902 is about 3+ walls and around 50ft (guessing) from it.
Thanks. I guess the Hubitat writes over the data each time the Ecowitt GW1000 sends a new set of data. I was concerned about storage problems on the Hubitat if it retains each set of data. I have the Ecowitt gateway set to send data every 3 minutes. Placement of the Ecowitt device shouldn't present a problem for me unless I get wild with future sensor locations.
Have added WH31B sensor to Ecowitt GW1000 but keep getting the following error:
dev:352020-05-14 06:24:08.829 pm errorEcowitt Weather Gateway - Failure to add Indoor Station F4CFA26A56EF and post temperature=75�F
dev:352020-05-14 06:24:08.822 pm errorEcowitt Weather Gateway - WeatherSensorChild driver is not loaded, this is required for child devices. Disabling children for rest of refresh.
Am I missing something - I thought the child sensors were auto-generated.
