Yep. Thatās what I did. It was unclear to me whether Somfy was using the ālong wire antennaā approach or wavelength multiple/fraction. So, when I did it on the 26931/26933, I just exactly doubled the antenna length. Itās best to solder a slightly longer antenna and then cut to length.
Iāve read 8in is the magic number for a US zwave frequency. Iāll try that. Worst case I ruin a relay that isnāt working anyway!
The existing antenna is probably about 3.25" overall? According to math that is what it should be anyway. So you probably want a 6.5" antenna.
According to the spec sheet, this runs at 908.4 HZ https://www.enerwaveautomation.com/wp-content/uploads/products/zwnrsm1s/ZWN-RSM1-Plus-0208160043-02.pdf
Seems about right. I didnāt measure but Iād say itās about 3in. Iāll play around tomorrow and see what happens.
We knew those engineering courses would be useful someday!
Most of what Iām seeing says a 5/8 wavelength antenna is optimal for Zwave and which makes the lengths for US Zwave
908.42MHz : wavelength = 0.33001526m -> 12.99inches -> ā wavelength = 8.11inches
916MHz : wavelength 0.32728434m -> 12.88inches -> ā wavelength = 8.05inches
Do you have a floodlight fixture on the house? I use one of these (actually I have the first gen model) HS-FLS100+ G2 Z-Wave Smart Floodlight Sensor | HomeSeer and it gives me 90' range to a motion sensor I stuck out in the backyard.
I have one of the first gen ones already. Not sure is the Gen2 has better range? Mine is probably ~100ft away from these devices.
As a plan B, does anyone know if you can buy tasmota sonoff relays, or do I have to flash them myself? Flashing sounds like a bit of a pain. I'm really trying to keep this simple. Again, it used to "just work" on a C5, so I don't want to get super crazy just to get somethign working that already did!
Did you look at the Shelly dual? It's WiFi but fully supported from Hubitat.
I didn't. Is it local though? Really trying to to avoid cloud.
quote:
- EMBEDDED WEB SERVER - You can set up Shelly without the need of any additional controller or hub, thanks to the embedded web interface.
/quote
Awesome! This may be the winner if I can't get the zwave going! Unfortunately I'll need two single relays (the two devices are too far apart) and it looks like the single relay is almost the same price as the double.
My mistake. I read your OP with "Enerwave Relays" and just jumped an opinion you meant the dual Enerwaves.
Np. I own a couple dual enerwave but I was never able to get them to pair with HE
We have been expecting a Hubitat built in driver for the Enerwave Zwave Plus dual relay for some time. There are two versions of the driver that is now floating around.
If you can't get that to work, I suggest going with the AEOTEC nano. It has a better antenna.
If that doesn't fit your requirements, I suggest using the Zwave RGBGenie device (for which there is a built in driver), and it's not expensive.
Worked great for an hour. Hubitat said āhold my beerā and promptly ended that.
I tried putting a Ge outdoor outlet next to the lamppost. All that did was cause the Ge outlet to stop working too. So discouraging. The C7 seems to have a far worse radio than the C5.
Here is my resent experience with ZWave Disaster.
I have a related (relatively long) thread for this case:
In short;
- All ZWave related problems started immediately after moving from C-5 to C-7;
- Adding repeaters did not do any good at all.
I installed a dedicated Aeotec 7 repeater but this specific one is not doing any
routing at all after about 6+ weeks being installed.
Also populated virtually every outlet with Plugin Outlet or Dimmer just for
routing reason. Neither one is doing any routing.
All my routers - are few Aeotec Micro Dimmers installed about 2 years ago
originally on C-5 hub and migrated to C-7 via Hub Migrate option.
Also I had to clean up ZWave network from few ghosts and retire bunch of
Zooz toys which worked perfectly fine with C-5 hub.
Yeah. The C7 definitely works for some people, but I'd recommend anyone who has a working C5 to not upgrade. There seems to be very little benefit, and lots of challenges for some of us.
