Problem with Sensibo A/C Temp state
Hi everyone!
I have got a weird problem. Hubiat "reads" my sensibo A/C controller always with 25,2°C
When i start the sensibo app, the temperature shows up correctly.
Ist there anything i can do for a correct readout?
Thank you all!
Peter
Has the link between the sensibo and hubitat gone¿ Mine was always doing that so I stopped using it with the hub. Check the hub integration app for sensibo and use the connect or reconnect option and see if that improves things
I will try that at home!
Tried the reconnect, still the same problem
Update:
When i turn the AC on/off via the sensibo app, then the temparature gets updated on the hubitat dashboard.
Is it possible to add the feature "asking the sensibo app more often for the temp?"
