Hi, is there a problem to create rule that will pause another one ?
im selecting rule to be pasued -> update button and ... nothing is happening
I have not noticed any problems with this myself. Could you post a screenshot of your rule?
im selecting rule
when i push update button at the bottom nothing happens
and button done with action is also missing...
Your screenshot looks odd. What version of firmware are you on? I don't get an update button next to select rule type to pause. It's just two drop downs one for the rule type and one for the rules. Once I select a rule type and rule, you get a DONE WITH THIS ACTION button.
version: 2.2.8.156
i have in every stepp update button, i'm selecting type rule and rule and nothing is happening....
Normally, once you have selected everything that needs to be selected and click off the last drop down, the « done » button should appear.
Have you tried starting over just in case? Also, be sure never to use the back button on your browser while editing a rule as it will most likely corrupt it.
Yes I have try several times, even I have cleared web browser cache all the time the same problem
What browser do you use? Have you tried another?
I have try different browsers even on phone
It’s very odd… I tried the same in Rule Machine and also Rule Machine Legacy:
- I don’t have “Update” buttons appear for any of my drop downs
- As soon as I move off the last drop down box, a “Done with this action” button appears.
Can you try rebooting the hub, just in case it might make a difference?
After rebooting the same problem, buttons etc
Is Chrome one of the browsers you have used? It tends to be the one that gets recommended the most.
You appear to have turned on the text reader function. Go to Settings / Hub Details, and turn it off (unless you are visually impaired and doing it on purpose).
yes, chrome, firefox, edge
how can it be turned off? i do not see "off" choice, i can change language only to diffetent.
yea ! now it works ! thanks guys !
